OK, so my third project is almost complete. I have built a P88 preamp with boards supplied by Mr. Elliot. I have had the preamp in services with the recently completed Leach amp and the sound is awesome. Of course I wouldn’t be posting if there wasn’t one small problem. I built the amp with the balance and volume control as per the P88 instructions. (see attached)
The problem is the balance control only affects the left channel. Turning the pot full right results in signal to only the right channel. However, there is no effect on the right channel so turning the pot anywhere left of centre results in a balanced signal between the two channels. I have rewired the volume and balance pot three times making sure all connections are done as outlined above. Does anyone have an idea of what could be causing this problem. The pots are a single 10K for balance and a dual 100K for volume linear pots as outlined in the diagram. Any ideas or comments would be appreciated. Thanks, Curioprop |
#2 |
Unfortunately I am at work and cannot investigate this right now but I cannot think of anything beyond a faulty pot, which would cause this. The wiper (2) is working in correlation to the left channel (3) but not the right (1) Does this make sense??
Any other thought are appreciated. |
#3 |
yep, P88 works, I have built 2 allready for less important projects...
#4 |
Hi Curioprop,
It appears that your 10K pot is open on the right channel side. Can you measure the resistance between to two outside terminals? -Chris
"Just because you can, doesn't mean you should" © my Wife |
#5 | |
The right channel of the pot is open. If I push the terminal forward it makes contact and I get a reading (about 11K). I have a backup I'll try and see if that does it. Thanks Again Steve |
#6 |
Hi Steve,
Good luck on this. Your other pot should be good. -Chris
| 26 preamp problem | NickC | Tubes / Valves | 7 | 13th February 2006 01:12 PM |
| preamp ps problem | Briney | Tubes / Valves | 12 | 18th November 2005 12:21 AM |
| Need help w/ NAD preamp problem | Jim B | Solid State | 13 | 3rd May 2005 02:41 PM |
| Mic preamp problem | kimarin | Solid State | 1 | 29th October 2004 09:11 PM |
| X2 preamp problem... | audionuts | Pass Labs | 1 | 28th October 2004 02:28 PM |
| Page generated in 0.08214 seconds (77.76% PHP - 22.24% MySQL) with 11 queries |
