Old 14th July 2007, 10:49 AM   #1
Jan Dupont's Avatar
Send a message via MSN to Jan Dupont
Default Input Noise Guarding of OPAmps
What's the best way to make Input Noise Guarding of OPAmp input circuits ??
Many uses Ground Plane, but BURR-BROWN recomends this:
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com
Old 14th July 2007, 01:10 PM   #2
djk is offline djk
djk's Avatar
That kind of guarding is usually for those that use cheap boards and want high impedance inputs (Teflon boards cost about $1 a square inch last time I checked).
I had to use a guard ring on a low frequency spectrum analyzer integrator cap, otherwise the charge would bleed off too fast.
Candidates for the Darwin Award should not read this author.
Old 14th July 2007, 01:15 PM   #3
Bonsai is offline Bonsai  Taiwan
Jan, this technique usually has nothing to do with noise reduction as applied to audio. Basically, the idea of the guard is to prevent leakage currents on the PCB from upsetting the DC performance of the op-amp. The guard ring is tied to a low source impedance which is at the same potential as the inputs. This can be accomplished by buffering the feedback voltage divider with a second opamp. The guard ring intercepts any leakage currents arising from delta voltages elswhere on the pcb .
Note that or this echnique to work, a double ided PCB is required (if using more than 2 layers, GR is required on every layer).
Might reduce very low frequency leagage noice in an mc amp, but I only have (good) experience using this technique on thermocouple amps.
bonsai
http://www.hifisonix.com/
Old 14th July 2007, 01:16 PM   #4
good point from djk - giard ring is absolute must for integrator applications - usually in dual slope A-D applications
bonsai
Old 14th July 2007, 03:08 PM   #5
Jan Dupont's Avatar
Thanks all
I was just wondering....
Old 14th July 2007, 04:09 PM   #6
Juergen Knoop's Avatar
to prevent leakage currents I bend the input-pins and wire them free air.
But thats not audio
regards
Old 14th July 2007, 11:02 PM   #7
jackinnj's Avatar
But thats not audio
regards
called "dead bug" -- popular in low power ham radio applications as well.
Old 15th July 2007, 03:58 AM   #8
I try to make use of sockets as much as possible
Old 15th July 2007, 04:37 AM   #9
anatech is offline anatech  Canada
anatech's Avatar
Hi ACD,
If you need to go to that extent, air currents can generate much more noise also. One of those things. Thermal drift is also noise, and once again air currents can really mess things up.
-Chris
Edit: Hi juergenk,
Sockets tend to make everything much worse. From capacitance to thermocouple effects. Many more paths for leakage too!
"Just because you can, doesn't mean you should" © my Wife
Old 15th July 2007, 05:02 AM   #10
Hi Chris,
thats not an audio circuit, the (+)input-pin is bend up to preserve the GOhm input impedance and avoid leakage currents.
The socket doesn't hurt in this special application.
Guess the hints in the BB datasheet weren't meant for audio circuits too.
FS: Capacitors/ Opamps/ Power Transistors/Noise Filters & Other Interesting Stuff dtm1962 Swap Meet 1 8th February 2006 04:21 PM
Reduce input noise YUTK Solid State 18 27th December 2005 12:04 PM
Low noise input? MikeW Pass Labs 11 21st September 2005 11:57 PM
T Amp input noise pixpop Class D 9 27th May 2005 04:54 PM
Input selector using PS gating of opamps? tcpip Solid State 11 24th February 2004 01:06 PM
Page generated in 0.10826 seconds (77.46% PHP - 22.54% MySQL) with 11 queries
