Best low budget OPAmp ?
Old 14th July 2007, 07:20 AM   #21
hienrich is offline hienrich  Philippines
hienrich's Avatar
Indeed.......
most might have forgotten them.......
"to invent, you need a good imagination and a pile of junk..." - Thomas Alva Edison
Old 14th July 2007, 07:22 AM   #22
Jan Dupont is offline Jan Dupont  Denmark
Jan Dupont's Avatar
Send a message via MSN to Jan Dupont
Most wasn't born when the LF356 came on the market
Free Schematic and Service Manual downloads www.audio-circuit.dk, Spare time company (just for fun): www.dupont-audio.com
Old 14th July 2007, 10:43 AM   #23
djk is offline djk
djk's Avatar
Hmm....
I may be in the minority here. I think the TL07X series sounds better than the LF35X series, and I find the OPA604 series to be quite a bit better, top-to-bottom.
The NE553X series sounds so much better as the front end of an amplifier than the LF/TL stuff, and doen't suffer phase inversion and latch-up when overdriven (of course no one here would ever overdrive an amplifier).
Another old opamp that sounds quite good as the front end is the LM318, although it is much faster than it needs to be.
Candidates for the Darwin Award should not read this author.
Old 14th July 2007, 10:55 AM   #24
Jan Dupont's Avatar
djk;
Your are right
It all depends on the use.....
I would never use either the LF35x or TL0xx or for that matter the NE553x series in a low signal aplification stage (e.g. RIAA stages etc.), however it's funny to swap those DIP's around and hear the differences
Old 14th July 2007, 11:01 AM   #25
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
Well if you realy want budget/old then try Rc1458..
Hmm,that would be a double 741..
Regards ┼ke
Old 14th July 2007, 11:20 AM   #26
Nordic is offline Nordic  South Africa
Nordic's Avatar
LM318 is what is in the frontend of the Mauro Penasa My_ref C, if my memory serves me well... with the designer being rather adamant about the use of this chip.
Old 14th July 2007, 01:04 PM   #27
djk is offline djk
djk's Avatar
The LM318 was the front end for all the older BGW amps too, 70V/ÁS in inverting mode.
Old 14th July 2007, 04:27 PM   #28
Conrad Hoffman is offline Conrad Hoffman  United States
IMHO, the LM318 is prone to instability, and very hard to use correctly. I'm wary of it, but one interesting application is an old National circuit app for a preamp. They used the mess-o-parallel transistors, the LM394, as a replacement front end, with the signal sent into the comp pins (I think). I built this circuit and it was stable and had fantastic noise performance. Sounded good too, but sort of useless info, since I think everything sounds the same if it has sufficient bandwidth, and doesn't misbehave in terms of crossover or instabilty. Your ears may be better. Unfortunately, I don't think the LM394 is made anymore, and the suggested replacement I saw doesn't use the exact same technique.
Old 14th July 2007, 06:15 PM   #29
juma is offline juma  Germany
juma's Avatar
For buffer or preamp (from RIAA to headamp-but don't go below 64 Ohm load): AD797 beats them all
For active filter: LT1361 - nothing comes close to it
Fully differential amplifier: OPA1632 (THS4131 is almost the same thing, it just wants a bit more RF taming).
P.S. I tried almost everything produced by Analog Devices, Linear and Texas Instruments.
Please don't use private messages for question related to audio projects. It defeats the purpose of the forum.
Best low budget OPAmp ?Hide this!Advertise here!
Single supply opamp - unequal rail voltage and opamp selection Hans L Parts 8 19th February 2006 02:15 PM
Regulate the psu of a power opamp with a similar power opamp? Franz G Chip Amps 34 19th October 2004 10:49 AM
How bad is budget? Pbassred Solid State 10 27th March 2004 06:53 PM
Help with my budget sub diy vegeotto Subwoofers 2 24th January 2004 03:21 AM
Budget BOZ Taco Pass Labs 3 25th November 2002 10:48 AM
Copyright ©1999-2017 diyAudio
