Diy Solid State Preamp
Old 12th July 2007, 12:31 PM   #1
Pocoyo is offline Pocoyo  Indonesia
Pocoyo's Avatar
Default Diy Solid State Preamp
i always look all the best amplifier
From Aleph, AKSA, Audiosector, Aussie, BPA300,
Bora, DX, JLH, Krell, Leach, Symasym, To Quasy.
ECT
Theres a lot best solidstate amplifier for DIY
But i just saw bride of son of zen (Aleph 1.7)
But where the DIY Active Preamp ?
Is anybody can build this Preamp ?
Is difficult to make hi end Preamp ?
Old 12th July 2007, 12:53 PM   #2
The difficulty is getting everyone to agree.
gain or no gain.
active or passive.
chip or discrete.
balanced or unbalanced.
switched, wiped, solid state or led volume control.
switched, solid state, relay or reed source selection.
RCA, BNC, XLR or DIN connectors.
tone control or not.
channel balance, mono switch, stereo or multichannel.
Start computing the permutations and there is a different combination for every member of the Forum.
regards Andrew T.
Old 12th July 2007, 11:30 PM   #3
Gordy is offline Gordy  United Kingdom
Hi jeffry,
I think Andrew is right. To design and build is not so difficult, but everyone has different requirements.
Old 13th July 2007, 12:00 AM   #4
Hartono is offline Hartono  Indonesia
gain or no gain.
active or passive.
chip or discrete.
to add to the list:
voltage feedback, current feedback
no global feedback, global feedback
low impedance pot, high impedance pots
jfet , bipolar
pcb, point to point wiring
simple pre-amp , complex pre-amp
battery, mains supply
ARGHHHH~~~~~~~
Old 13th July 2007, 12:10 AM   #5
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
What is difficult and what is high end ?
I've started putting together a preamp design that has 300 active devices, 250 capacitors and 600 resistors in the amplification sections alone.
Likely very high-end, but do you care to do the same ?
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 13th July 2007, 02:55 AM   #6
anatech is offline anatech  Canada
anatech's Avatar
Hi Jeffry,
I guess a true high end" preamp is one that sounds very good to many people who are familiar with this class of product, and has reasonable specifications. I would expect the finish to be presentable.
Can you build one? Probably. You just need to set your priorities and build it some how. An existing design is fair game.
Hey Jacco!,
You're smuggling parts again, aren't you!
-Chris
"Just because you can, doesn't mean you should" © my Wife
Old 13th July 2007, 05:05 AM   #7
sandyK is offline sandyK  Australia
Jacco
Any Stereo preamp that has 300 active devices,250 capacitors, and 600 resistors in the amplification section alone,
(unless of course, you are being facetious, and counting the internal bits inside a few integrated circuits !) is sure to be high end in price only.
I would have thought that you subscribed to the K.I.S.S. principle ? Smacks a bit of Dinosaurs and pink pigs , aimed squarely at some forum members!
SandyK
P.S. Sincere apologies in the unlikely event that you are being deadly serious.
Old 13th July 2007, 07:14 AM   #8
Nordic is offline Nordic  South Africa
Nordic's Avatar
I can recommend only one DIY preamp at this stage... pedja rogic's jfet buffer.
Old 13th July 2007, 08:36 AM   #9
MaxS is offline MaxS  France
Hello sir,
I remember a PMA project called Dispre. Full of his favorites BJT.
diyAudio thread :
http://www.diyaudio.com/forums/showt...threadid=64843
BOM :
http://www.kubusmaximus.com/symasym/....php?id=dispre
The last one :
http://www.holgerbarske.com/news/index.php?shownews=209
If you can get DPA-111 schematic, send me a copy
EDIT : I've forgotten the schematics
Ca marche pas ! Tu ne l' as pas branché non plus ....
Old 13th July 2007, 09:21 AM   #10
Fully balanced, left and right channel.
Discrete Class A opamps, input opamps below and output opamps on the top of the pic.
JFET/ BJT/MOSFET devices.
Diy Solid State PreampHide this!Advertise here!
solid state metal preamp fingerwizards7 Instruments and Amps 34 3rd February 2011 10:02 PM
Tube preamp vs. solid state bushroot Tubes / Valves 16 31st October 2006 08:16 AM
hifi solid-state PREAMP ... Ahmad_tbp Solid State 34 20th June 2005 11:10 PM
Solid state preamp gchrist Solid State 4 7th April 2004 11:19 AM
PIC software programme for solid state preamp Jan Dupont Digital Source 4 20th January 2004 09:06 PM
Copyright ©1999-2017 diyAudio
