Sony STR-DE635 receiver no sound, what's blown? - Page 3 - diyAudio
Old 11th July 2007, 08:25 AM   #21
Netlist is offline Netlist  Belgium
diyAudio Moderator Emeritus
Netlist's Avatar
Originally posted by jamil5454
So, there is no IC1207 on the digital board (contrary to what the schematic says). I did, however find a 5v BA05T (IC1204) and after checking it's three pins none of them are shorted together.
Why not assemble the amp and check if you have 5V at the terminal of IC1204.
/Hugo
Old 11th July 2007, 05:33 PM   #22
anatech is offline anatech  Canada
anatech's Avatar
Hi jamil5454
Hugo has a good suggestion there.
-Chris
"Just because you can, doesn't mean you should" my Wife
Old 11th July 2007, 07:17 PM   #23
Uh oh.
I just reassembled the amp and now when I plug it in I hear a clicking noise (I think it's the power switch relay) that gets louder and louder until both 8A fuses blow on the AC board. It takes about 3 seconds. Hmmm, what could I have broken? Sigh...
Old 11th July 2007, 07:27 PM   #24
Bigred is offline Bigred  Canada
What is broken? Prolly more and more as you continue to replace fuses and power up the amp
Old 11th July 2007, 07:36 PM   #25
Netlist's Avatar
Maybe a mica insulator is missing on one of the power transistors.
/Hugo
Old 11th July 2007, 07:43 PM   #26
Oops, those were required? crap let me find them.
Old 11th July 2007, 07:52 PM   #27
LOL.... sorry to laugh but believe me, manufacturers nowadays skimp out on everything possible and they wouldn't have parts just for the heck of it. YES those were required. A thin film of heatsink grease prolly wouldn't hurt either. Also if there were insulating washers present with the mounting screws. NO SPARE PARTS
Old 11th July 2007, 07:52 PM   #28
Netlist's Avatar
If some or more were missing, make sure next time you power up to use a fuse of about half the required rating.
/Hugo
Old 11th July 2007, 08:05 PM   #29
anatech's Avatar
Hi jamil5454,
Oops, those were required? **** let me find them.
You're either having fun with us, or ..... oops!
Don't worry. I see technicians forget to install them all the time, or my favorite, the use two (results in overheated outputs).
You must clean the transistors, heatsink and the mica insulators. You must also use fresh grease. If an insulator is cracked or damaged in some way, it must be replaced. Those steps are not optional, sorry.
If this means you must put everything aside for right now, do it.
Can you just install everything for a quick test? Yes. Just clean all the old grease off everything and remount it dry. Don't run speakers for any length of time and keep the volume down.
-Chris
Old 11th July 2007, 08:25 PM   #30
Alright, I got those insulators out of the trash and applied some Arctic Silver to them and the transistors and still have the same problem. Obviously I thought it would be similar to a CPU heatsink but apparently not.
I will clean the transistors and heatsink off thoroughly and try it dry. I replaced the 8A fuses with 5A instant-blow ones so I should be ok there.
Thanks everyone for your help. I'm learning so much.
sony 6ch receiver help thetube0a3 Solid State 1 30th March 2009 06:41 PM
Please help: no sound and blown fuse spendorspain Tubes / Valves 6 11th December 2008 01:48 PM
Pioneer HT receiver... blown channel? infinitesymph Solid State 13 17th February 2008 10:50 PM
No power / repeated blown fuse in Sony STR-D915 dmworking247 Solid State 0 21st January 2008 08:37 AM
Blown Tangband 871 sound? Destroyer OS Full Range 2 3rd October 2006 05:48 AM
Copyright 1999-2017 diyAudio
