Optimus MPA 125 Blowing Fuses
Old 10th July 2007, 06:30 PM   #21
Bigred is offline Bigred  Canada
The outputs I would bet are blown along with possible power supply damage. As Chris mentioned earlier... by just replacing the blown fuse numerous times you may have inflicked even more damage. For the future I wouldn't replace a blown fuse without ATLEAST some preliminary checking (it went for a reason). Anyways.... a good start I think would be to check Q107 thru 112
D122
Old 10th July 2007, 06:37 PM   #22
kevinkr's Avatar
A couple of quick thoughts, perhaps Radio Shack can provide a schematic if you contact them via their website. Also it is possible that Sams Photofacts might have a schematic and service information for this model.
One thing working in your favor is it's old enough to be all through hole components, nothing like troubleshooting something with lots of smd parts as well.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 10th July 2007, 06:44 PM   #23
anatech is offline anatech  Canada
anatech's Avatar
Hi Brian,
Just a thought.
What were you going to use this amp for?
-Chris
"Just because you can, doesn't mean you should" © my Wife
Old 10th July 2007, 07:03 PM   #24
60fairlane is offline 60fairlane  United States
Hey Chris,
Primarily for an in home "studio" for lack of a better word. I'm going to be driving a couple of speakers (maybe up to four) with output from a variety of sources through a 5 channel mixer.
- Brian
Old 10th July 2007, 07:16 PM   #25
anatech's Avatar
Hi Brian,
This is only a single channel amp, isn't it? PA stuff generally dose not run in stereo.
-Chris
Old 10th July 2007, 09:02 PM   #26
Yeah this is a single channel. Can use it to run CD players and such but you obviously won't be getting stereo left and right separation
Old 10th July 2007, 09:13 PM   #27
anatech's Avatar
It may serve you better if you feel like building a stereo amp of lessor power in that case, depending of course on how much you paid for it.
You aren't going to run four speakers unless you run them on a 70 V line, or use a series parallel connection for them.
-Chris
Old 10th July 2007, 11:37 PM   #28
Chris,
Thanks for the ?? re: application - I honestly didn't even think about stereo separation. Keeping that in mind - what do you think I should do? Does this one end up in the "bin"? Are there any components that would lend themselves to other applications? Ok, I'll quit asking questions..(for now!)
- Brian
Old 10th July 2007, 11:40 PM   #29
I guess the rest of us are invisible here. Good Luck with your pa amp
Old 10th July 2007, 11:51 PM   #30
kevinkr's Avatar
Originally posted by 60fairlane
Chris,
- Brian
Depends on what you want to do, do you need stereo or will mono suffice? If you are interested in stereo one of the chip amp kits using the LM3886 might be just the ticket. There are several threads on the subject here. Otherwise you might still want to fix it.
Depending on power supply voltages the power transformer is definitely worth keeping as is that chassis and heatsink. You can probably package a kit amp in that box if you are a little creative.
There is undoubtedly a 70V/25V output transformer in this thing as well if it is for pa work. Does this unit have connections for high voltage lines - usually marked 25V or 70V out? For studio work this is generally not needed, and generally has rather poor bandwidth as well. The output transformer will have a bunch of wires going directly to the output connections on the back. (which I couldn't read unfortunately)
Optimus MPA 125 Blowing FusesHide this!Advertise here!
Car Amp help? Fuses blowing... Tolo Car Audio 1 3rd December 2007 01:42 PM
Why are these fuses blowing Darin P-B Solid State 41 30th May 2005 10:56 PM
Blowing fuses balance Tubes / Valves 2 5th March 2005 02:16 AM
blowing fuses homegrown45167 Car Audio 2 22nd October 2004 12:16 PM
The Fuses Just Keep Blowing raffir Chip Amps 19 22nd June 2003 03:49 AM
Copyright ©1999-2017 diyAudio
