Old 11th July 2007, 03:49 AM   #21
CBS240 is offline CBS240  United States
CBS240's Avatar
Don't under-estimate what can be done with a couple of cheap-O proto-boards. This stereo has been working great since Feb. I'm am listing to it right now. There is well over 100 transistors, almost all are SOT-23, in the entire circuit. SMD 603 resistors. About 25-30W/Ch.
All the trouble I've ever been in started out as fun......
Old 11th July 2007, 03:50 AM   #22
CBS240's Avatar
And...
Old 11th July 2007, 04:01 AM   #23
It must be nice to have some fruit of labour!
It is encouraging to see.
Annihilate all desire - Mahatma Ghandi
Old 11th July 2007, 04:34 AM   #24
hienrich's Avatar
hi guys
i just need to know about the advantages of having
some Sziklai pair in the input differentials
and I found it very interesting most specifically on the sonic side.
thanks
macweb
"to invent, you need a good imagination and a pile of junk..." - Thomas Alva Edison
Old 11th July 2007, 04:38 AM   #25
CBS240's Avatar
Hi
I had a few PCB's made for a new power supply board. The board house had a speacial for PCB's produced with top and bottom copper only. Cost was $89 for 5, and that cost was credited to the next a full spec board cost, IOW free. Those transfos in the picture came from some old junk that would otherwise have been garbage. But I couldn't stand to toss them, better to use them. I took all the iron out, re-wound the secondaries proper for my circuit, and reasembled the core. Lot of time spent, took several hours. One could spend LOTS of money on power transformers though. I try to spend as little as possible on proto-stuff, time spent developing it is bad enough.
Self-biasing class AB input stage Mr Evil Solid State 56 25th April 2009 08:53 PM
LED cathode biasing in push-pull input stage exeric Tubes / Valves 14 18th August 2008 02:35 AM
Output stage biasing, with the driver stage andrew_whitham Tubes / Valves 0 19th May 2007 12:14 PM
Page generated in 0.17904 seconds (40.20% PHP - 59.80% MySQL) with 11 queries
