SE J/MOSFET Class A Amp, no Feedback SE J/MOSFET Class A Amp, no Feedback - diyAudio
Old 8th July 2007, 10:51 PM   #1
widowmaker is offline widowmaker  Europe
widowmaker's Avatar
Send a message via ICQ to widowmaker
Default SE J/MOSFET Class A Amp, no Feedback
Here is my last project of two stages (common source & source follower) class A amp.
AgTa caps are K52-2, russian military production.
Amp was specially made for bulgarian fullrange driver Ether.
High Tension Wires Department
Daniel Petrov also known as widowmaker
Old 8th July 2007, 11:28 PM   #2
AKSA is offline AKSA  Australia
Daniel,
Nice circuit, nothing too unexpected.....
Could you describe the sound? Tubelike would describe it?
You have the usual Vgs distortion of the SE source follower.
Could I suggest something? A simple emitter follower regulator with heavily decoupled zener for reference on the input stages rather than the chip; in my experience it sounds better, more vitality....
Hugh
Aspen Amplifiers P/L (Australia)
www.aksaonline.com
Old 9th July 2007, 12:41 AM   #3
widowmaker's Avatar
Originally posted by AKSA
...Could I suggest something? A simple emitter follower regulator with heavily decoupled zener for reference on the input stages rather than the chip; in my experience it sounds better, more vitality....
Hugh
Of course, trans is better solution
Yesterday, when I made the prototype, I had only two 20V zeners on hand
Sound is deep and very fast with tight bass and bright mid and high freqs.
Output power is 17-18 watts (there is a mistake in attachment).
Signal (top) 1529 has current regime between 0.5 and 6.5A for full power(Imin and Imax) and dissipates 52-53 watts.
Old 11th July 2007, 02:52 PM   #4
Gordy is offline Gordy  United Kingdom
I have seen other circuits from you, and they are always interesting. Good luck.
Old 11th July 2013, 11:42 AM   #5
widowmaker's Avatar
Because of too many business trips abroad during last several years,
I was inactive for a very long time (from the end of 2007th i think).
I want to share with you one of my ideas, which is in fact the next step of this very simple design.
Actually this is an old design, I made it 6 years ago, but I didn't post it at that time...
Also (at the same time) I made some tests, using full range driver Ether 6, mounted in backloaded horn enclosure.
The amp has most of advantages of tube SE amps, OK, not all of them,
but it sounds great - with monumental, huge bass and more than enough "air between the notes"
The most important disadvantage is its prone to generate a wide harmonics spectrum,
which is tangible especially when listening poor quality records.
So, the schematic is very simple - first stage is common source with 2SK246BL - it makes all of voltage amplification of the amp.
The second stage is current follower (common drain), realized with one of best audio MOSFETs - Hitachi 2SK1056/7/8,
with constant current source, connected to its source.
Input stage is supplied more complicated - it has positive one +45V and the other one (negative),
which is ajustable and keeps the current of input transistor relatively stable in very wide temperature range.
The output stage is directly coupled to the input one. The idea is to get almost the same temperature drift for both stages,
i.e. to get zero offset (actually 1/2 Vdd) for wide temperature range (let's say something like 20-100C).
Old 11th July 2013, 06:38 PM   #6
widowmaker's Avatar
Ooops,
I typed mistakenly "current follower" instead of "source follower". Also I forgot to attach schematic.
(characteristics and linearity of BUZ900 are identical with 2SK1058 data).
SE J/MOSFET Class A Amp, no FeedbackHide this!Advertise here!
Class-A-Burn: an amp with capacitive feedback divider around MOSFET Wavebourn Solid State 35 30th August 2009 07:41 AM
True Current Feedback N-channel Mosfet Amp Workhorse Solid State 199 8th September 2008 04:44 PM
Cascoded -MosFet- Zen without feedback Tyimo Pass Labs 17 7th February 2006 12:40 PM
Mosfet class A p/p amp... is feedback required? nobody special Solid State 13 11th September 2004 06:30 PM
ClassA mosfet p/p amp with no feedback? nobody special Solid State 11 17th June 2003 05:41 PM
Copyright ©1999-2017 diyAudio
