My Leach Amp Clone (LEACH 150)
Old 8th July 2007, 10:34 PM   #21
panson_hk is offline panson_hk  Hong Kong
panson_hk's Avatar
Default Re: those transformers looking good with your great amp...
Originally posted by cyril_hk
Hi Panson where do you get your transformers, seem likes some kind of low profile version. Looks really great!
Anyway, I just finished mine right early of May, no current limiter too, with all home made PCBs.
http://hk.geocities.com/cyrilwoo/
Cheers
Hi, the transformer is a special order. Your Leach looks great too!
Old 9th July 2007, 10:04 AM   #22
panson_hk's Avatar
Default Re: Re: those transformers looking good with your great amp...
This low-profile transformer was originally ordered for a low-profile chassis. But I eventually use regular chassis for installing a big (original) heat sink.
Old 22nd August 2008, 11:26 PM   #23
tritosine is offline tritosine
hi, panson can you contact me please thru email? I cannot do the same...
Also , that missing 1W measurement would be very cool!! Another question, I found a pdf on www bout an lme49810 front end with Leach output stage, is that yours ? Im fairly sure its yours and Im extremely interested about that one !!
Old 24th August 2008, 09:40 AM   #24
panson_hk's Avatar
Here is 1W, 10W and 50W THD vs freq.
Yes, I this is my proposal. Thank you for your interest! I will post results of this project when available.
Old 24th August 2008, 09:40 AM   #25
panson_hk's Avatar
The amplifier (LEACH 150) has an on-board power supply (rectifier and reservoir cap 2200 uF x 8 per rail). I compared the THD of the amplifier for using its on-board supply to using a separate supply which has the same topology with 10000 uF per rail. Interestingly, THD at low freq region associated with the separate supply is better than its counterpart.
I also measured THD for using onboard PSU with an external transformer (same as internal). This helps us to make more meaningful comparison.
It can be seen that using a separate PSU achieves lower THD in low freq. region. It seems obvious the on-board PSU layout responsible to the degraded performance.
Old 24th August 2008, 03:53 PM   #26
panson_hk's Avatar
This is THD for 1W, 10W and 50 W figure.
Old 16th September 2008, 03:21 AM   #27
panson_hk's Avatar
I continue my journey of the above distortion evaluation. The rising low frequency THD is probably due to on-board reservoir capacitors’ charge and re-charges current. The capacitors are located very close to input terminal. They share the same ground plane (top layer). The ground area between +V rail caps and –V rail caps are very noisy. Hence, the input ground is polluted.
Old 16th September 2008, 03:37 AM   #28
panson_hk's Avatar
I measured the waveform between ground A and B. Non-zero PCB resistance given non-zero voltage between A and B when there is current flowing. Since input ground point is in the middle of the current path of A and B, input ground is polluted.
Waveform between point A and B, and distortion residual are shown. You can see the two signals are correlated to some extent.
PS: Distortion residual means remaining signal where the fundamental component is removed.
Old 15th August 2011, 08:12 PM   #29
Hocdm is offline Hocdm  United States
I actually have a set of these same blue pcb's I got off ebay a couple of years ago. They came with dc servo boards also. At the time I bought it, it was advertised as a full kit. Once I received only the pcb's I checked the listing again and in small, ultra fine print at the bottom it said "pcb's only." I guess I should have looked everything over more carefully.
I never could find a parts list for the things. Diyzone doesn't seem to exist anymore. Anybody here have a parts list for this clone?
Old 26th February 2014, 03:40 AM   #30
flaviohpr is offline flaviohpr  Brazil
Send a message via MSN to flaviohpr
Hi. I need that part list too. Please!
My Leach Amp Clone (LEACH 150)Hide this!Advertise here!
DC SERVO Leach 150 clone giulianodes Solid State 7 27th August 2009 05:44 PM
Leach clone Linval Group Buys 0 23rd October 2008 05:15 PM
Leach Amp Clone/10 transisitors marcony Solid State 1 31st July 2006 11:44 AM
Leach Amp Clone marcony Solid State 1 19th July 2006 07:36 AM
Leach Amp Clone/10 transisitors marcony Class D 1 13th July 2006 02:26 AM
Copyright ©1999-2017 diyAudio
