hy mr holton
hy mr holton
Old 5th July 2007, 11:15 AM   #1
retrosong is offline retrosong  Romania
Wink hy mr holton
tancx for proiect av 800 ist very very good amplifier my is very very hapy
Old 7th July 2007, 03:47 PM   #2
i aem av 1200w/4 and 12 tranzistors irfp 240 -9240 per devices end power suply +- 115 vcc
Old 7th July 2007, 03:51 PM   #3
Default av1200
av 1200 amplifier
Old 7th July 2007, 08:52 PM   #4
Netlist is offline Netlist  Belgium
diyAudio Moderator Emeritus
Netlist's Avatar
Welcome to the forum.
What speakers will you use and is this picture your amplifier? Very nicely build.
/Hugo
Old 8th July 2007, 12:16 PM   #5
east electronics is offline east electronics  Greece
east electronics's Avatar
Default only .....
from the picture i ve seen .......
this will not stand full power ...... if you push it to the limit is simply gona blow......
laying all these transistors on a heat sink and using just a piece of wire to supply them will have a serious drop of voltage from side to side ...... i f you supply them in the midle then you will have drop in the voltage on the sides ...... if you supply them with more than one cable will solve the voltage drop problem but to my opinion will also create ocilation ......
different voltage in every trs will create the thing that actually some transistors will not help others or not share load ecually..... curent resistor also will not help in this level of diference
let us now how it works i am curious
Old 8th July 2007, 05:44 PM   #6
this amplifir functionality with 2 years never nou problem in functionaliti in 2 yars la power suply +- 115 vcc this amplifier ist very good in functionality end very strong mr hohton is one genius scuzmi for bad englich anthoni(the saint) ist the best
Old 8th July 2007, 09:30 PM   #7
zerohead_ak47 is offline zerohead_ak47  Turkey
Send a message via AIM to zerohead_ak47 Send a message via MSN to zerohead_ak47
schema pls
Old 8th July 2007, 09:42 PM   #8
the schematic ist av 800 you must eliminiert irf 610 and 9610 and R43 you must change Q23-irf 610 with bd 139 and atacly directly ist modification ist very very stabile function no goig in temperaturi irfp 9240 -240
Old 9th July 2007, 02:31 PM   #9
Default well....
sorry but with this you say +-115 volts this machine will produce more than 500w .... i think ( prsumed is AB) di you everoperated this amp at this power ????
Old 11th July 2007, 04:23 PM   #10
this is av 1000 pcb
hy mr holtonHide this!Advertise here!
Holton's AV400 bigpanda Solid State 29 5th January 2005 05:31 PM
Q13 in Holton's n-channel amp Pelle Solid State 21 10th October 2003 05:56 AM
Copyright ©1999-2017 diyAudio
