Old 3rd July 2007, 08:07 PM   #1
Question hello! :) and a small question
hello!
cool forum!
i am looking for a Service Manual for the Setton BS-5500 amplifer.
mine is broken and id like to fix it.
thanks!!!!
Henry
Old 4th July 2007, 01:58 AM   #2
djk is offline djk
djk's Avatar
Good luck.
What's wrong with it?
It's just a typical made-in-Japan piece from the mid 70s, nothing fancy. Should be able to fix an amp problem without a schematic.
Candidates for the Darwin Award should not read this author.
Old 4th July 2007, 02:09 AM   #3
anatech is offline anatech  Canada
anatech's Avatar
Hi theblackknight,
Welcome to DiyAudio!
djk is right, any good tech could repair that with no docs. However, you aren't so let's go.
Do you have a circuit diagram?
Can you take a picture of the inside?
What is your exact complaint. No power rates as an exact complaint (as in no lights - nothing).
-Chris
"Just because you can, doesn't mean you should" © my Wife
Old 4th July 2007, 03:55 AM   #4
the left side wont go out of protection due to a leaky PS cap.
i want to replace all four caps myself, but i need the manual to reset the bias and offset.
thanks!
Henry
Old 4th July 2007, 04:07 AM   #5
anatech's Avatar
Hi Henry,
Interesting. It must be right open so it appears to the protection that there is an offset.
Replace the caps first, no gerfingerpoken yet! Those adjustments should be close unless something else is going on.
-Chris
Old 4th July 2007, 07:24 AM   #6
on the bottom of one of them there is a tiny hole on top of a bump that was covered in gunk.
didnt know something so small could cause such big problems!
i also just found replacements at mouser electronics. i have not ordered them just yet, but they are EXPENSIVE! $20 each!
http://www.mouser.com/search/Refine....RefType=Header
and, they arent the right size! the old ones have a 5cm diameter, and are only 6cm tall, while the new ones are 4cm by 8cm.
what should i do?
once/if i replace them, can i go ahead and use it? or do i have to take it to a tech to have the bias current and DCoffset adjusted?
thanks!
Henry
Old 4th July 2007, 08:52 AM   #7
Symon is offline Symon  United Kingdom
Hi Henry,
I just looked at the link, it says there is a min quantity of 64, also
these capacitors aren't stocked.
Symon
Old 4th July 2007, 03:48 PM   #8
oh. your right.
where should i order them from, then?
and what should i do if they dont fit?
thanks for the help!!!!
henry
Old 4th July 2007, 03:58 PM   #9
anatech's Avatar
Hi Henry,
Simple. Try Newark and Digikey as well.
-Chris
Old 15th July 2007, 05:03 PM   #10
do you think these will work?
http://www.newark.com/jsp/Passives/C...sp?sku=30K6620
the only problem is, the old ones are 5 mm dia and 6 mm tall.
will these work also?
what can i do to make them fit?
thanks!
Henry
I want to start small, have a question about a toroid beerman Chip Amps 6 28th February 2007 09:38 AM
Small question about boats and rivers Netlist The Lounge 2 16th May 2006 12:56 AM
Small value resistor question Thomas001 Multi-Way 4 14th January 2005 02:15 AM
newbie question theil small psychosteve Multi-Way 9 1st October 2004 03:18 PM
A small question... maybe not Guydot Tubes / Valves 4 18th June 2003 02:49 PM
Page generated in 0.11069 seconds (74.24% PHP - 25.76% MySQL) with 10 queries
