I'm looking for a nice Class A mosfet based amp that will do 100wpc at 8ohms. I'd like it to be a PCB that is available somewhere that I can buy right now. Any idea's? Right now the speakers are Klipsch Reference but eventually it will be large 3 ways using RS driver most likely.
#2 |
The chances of finding a 100W ClassA PCB is near nil.
regards Andrew T. |
#3 |
If you really don't know: the A75 design by Mr Pass and Mr Thagard.
You can download the two parts of the A75 building manual from Mr P., order the A75 main board from AudioXpress.
Looks like Sponge Bob has killed another thread. |
#4 |
Well 60 wpc at 8ohms would be enough. And over 100 at 4ohms would be nice.
#5 |
Is there a BOM for the Aleph 5 somewhere? I've searched and can't find it. I'm thinking of ordering the boards from chipamp.com and building a pair of Aleph 5's.
#6 |
ClassA output power is limited by the level of ClassA current available. If you have a 60W into 8ohm ClassA output and instead connect a 4ohm load the maximum ClassA output drops to 30W. Use P=I^2*Rload instead of the usual P=V^2/Rload to see the effect of a load change.
regards Andrew T. |
#7 |
http://www.ska-audio.com/diy/003.html
GB300D (mono) Bare PCB US$60 + $4 p&p Full module kit US$135 + $8 p&p Built/tested module US$200 + $12 p&p
Candidates for the Darwin Award should not read this author. |
#8 |
Good one, Dennis.
Dougie, you can still use IRFP9140s for the full Class A version of the GB300D. No idea how the Class A version of the 300 sounds, i haven't read of someone constructing one yet, the GB150D in 50 watt A i assembled is excellent value for money and really fast to put together. Ordering the IRFP9140 is apac on your end.
| PCB design for MOSFET based HP amp? | zebra100 | Solid State | 0 | 1st July 2009 09:01 AM |
| Fault with MOSFET based headphone amp | zebra100 | Headphone Systems | 8 | 7th October 2008 03:29 PM |
| Op Amp Based Mosfet Power Amplifier | Dusk | Solid State | 0 | 17th July 2005 06:13 PM |
| Opamp based MOSFET amplifier design | ronybc | Solid State | 33 | 28th July 2004 05:48 AM |
| MOSFET based TRANSFORMER COUPLED CAR AMP | Workhorse | Solid State | 2 | 26th January 2004 10:57 PM |
| Page generated in 0.09094 seconds (76.57% PHP - 23.43% MySQL) with 10 queries |
