I need help on TDA7375
Old 1st July 2007, 04:09 PM   #1
ahonda55 is offline ahonda55  Egypt
Default I need help on TDA7375
Hi all, i am new to this great forum and i need help to make a simple amplifier to play my mp3 player in my car.
first i have searched in the forum and found that the TDA7375 is good to start with.
i have 2 speakers 4ohms impedence.
from the data sheet i got this
because i have read that the bridged amplifiers can produce better watt.
should i start building it now exactly like the datasheet diagram? or i have to make anything else?
and how can i make the sound loude enough to be heared in an old car on travelling.
and what is pin 7 used for (ST-BY) ?? and what should i connect it to ??
and the most important question, i see pins 1,2 and 14,15 are connected to the speakers, it is like +/- or 1,2 are tied then connected to the (+) terminal and the other is ground and the same with the other speaker ??
i hope you understand my bad english
i am so sorry because of my long questions
please help
Thank you very much
Old 1st July 2007, 04:52 PM   #2
sorry posted the topic in the wrong place
please moderators move it to amplifiers solod state section.
thank you
Old 1st July 2007, 04:54 PM   #3
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
Done.
planet10 needs your help:
Let's help Ruth and Dave
Old 2nd July 2007, 08:17 AM   #4
thanks
but, still nobody replayed !!
pleaaaaaaaase answer my questions mates
Greetings
Old 2nd July 2007, 08:48 AM   #5
Eva is online now Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
Pin 7 is used to turn on and off the amplifier without physically connecting and disconnecting it from the 12V supply. Connecting this pin to ground turns the IC off, and connecting it to 5V (always through the recommended RC filter) turns the IC on. Don't apply more than 5V to this pin to avoid damage to the IC (you will probably need a small 5V regulator or a zener diode).
The speakers are connected just as your diagram shows. Pin 1 is L+, pin 2 is L-, pin 15 is R+ and pin 14 is R- (they forgot to state the polarity but it becomes obvious by looking at the other figures). Thus, the two terminals of each speaker have to be wired independently to the IC (no common ground). This is called bridge tied load (BTL).
I use to feel like the small child in The Emperor's New Clothes tale
Old 2nd July 2007, 03:05 PM   #6
Thank you very much Eva
i will start to build it very soon.
greetings
Old 2nd July 2007, 08:34 PM   #7
Sorry, another question please
in this diagram the sound volume is fixed, how can i make a volume control on this, i think it will be something like changing the input inverting or non inverting input by making a voltage devider, but which riostat should i use, i mean 100K 50K ... etc.
and where should i connet it, it will be 2 ristats one for every speaker?
i am confused about it !!
many thanks
greetings
I need help on TDA7375Hide this!Advertise here!
Help with tda7375 Nenola Chip Amps 7 3rd March 2009 02:15 PM
TDA7375 as a subwoofer amp JAZZ2250 Chip Amps 5 18th May 2005 05:31 PM
Copyright ©1999-2017 diyAudio
