OPA4228 runs hot - diyAudio
Old 1st July 2007, 03:12 AM   #1
iron25 is offline iron25  United States
Default OPA4228 runs hot
Hello folks,
I hope to find help here as the engineers at TI have no answers!!!
They say there was a thermal issue but was never followed up on!!!
I replaced TL074's with the 0PA4228 and while the sound is greatly improved the op amps seem to run quite a bit hotter in temp. I am also having the same problem with the dual version.
Has anyone had any similar experience? Solutions?
Thanks for your help!!!!!
Old 1st July 2007, 10:09 AM   #2
djk is offline djk
djk's Avatar
If you read the spec sheet you will find they draw twice as much power, so they should run hotter.
Spec for the quad version says about 0.45W at 15V, a bunch for this small package.
Candidates for the Darwin Award should not read this author.
Old 1st July 2007, 05:42 PM   #3
I didn't consider the draw, everything else seems to be fine.
Thanks for pointing that out!!!
Sometimes the obvious isn't so!!!
Looking for amp kit that runs on 12V (car battery) maurycy Chip Amps 5 2nd October 2008 08:29 PM
Dynaco ST-120 runs hot bobgroger Solid State 6 15th April 2008 05:20 AM
PC speakers amp runs ac?? Does DC work? NeMeSiS_singh Power Supplies 8 14th June 2006 10:35 AM
OPA4228 help needed afxdave Chip Amps 2 8th April 2004 04:25 PM
BOSOZ's PSU runs very very hot ruangrit Pass Labs 18 5th February 2003 11:45 PM
Copyright 1999-2017 diyAudio
