remote control going wild
Old 29th June 2007, 12:04 PM   #1
SharpyWarpy is offline SharpyWarpy  United States
SharpyWarpy's Avatar
Default remote control going wild
When I use my remote control on my Fisher amp sometimes it goes wild, volume increase will keep going up or down, cd track change will keep going up or down. Any ideas on what might cause this? I'm leaning towards a bad IC, but I'm new at this. It's an old Fisher Studio Standard CA885. I have the schematic and manual -- it's pretty complicated and a lot of things run together. Would it be worthwhile to start replacing chips? Thanks.
Old 29th June 2007, 12:34 PM   #2
BrianDonegan is offline BrianDonegan  United States
BrianDonegan's Avatar
Try to get it to happen again. In the midst of it's misbehaving, cover the end of the remote with your hand. Does that stop it?
My first guess is sticky goo in the remote's buttons. Always suspect mechanical items first, electronic second.
Old 29th June 2007, 12:59 PM   #3
Thanks for the reply
I disassembled the remote and cleaned all the buttons, this did no good. When I pull the remote away from the amp it still runs wild, so I guess that pretty much eliminates that.
Old 29th June 2007, 08:55 PM   #4
jaycee is offline jaycee  United Kingdom
I would start by replacing the IR reciever - they're cheap enough to just swap out
If that isn't the problem, then it only really leaves the microcontroller - if that's gone bad then you are pretty stuck.
Old 29th June 2007, 09:41 PM   #5
Greg Erskine is offline Greg Erskine  Australia
Greg Erskine's Avatar
First I'd check the following before getting the soldering iron out.
Check there are no other IR controls nearby causing the problem.
Cover the IR reciever to confirm there are no external influences.
Open it up and reset any cables or socketed devices.
Greg Erskine
remote control going wildHide this!Advertise here!
Remote volume control for existing remote? theAnonymous1 Parts 7 6th August 2007 08:22 AM
The remote control paratactic volume control audio-gd Solid State 33 7th June 2007 11:16 PM
Tone Control Gone Wild...(could use some guidance) EchoWars Solid State 26 23rd November 2005 08:29 AM
remote control motorised control for volume pot/knob CharlesY Parts 0 25th July 2005 11:12 AM
