Banned
The Web Page that I found is:
http://aktobos.wz.cz/100w.html There is a amplifier its uses one pair of mj15003/04 I like to use as a car amp wit subwoofer of 400W Can it handle it or wath? |
#2 |
Did it Himself
You need a SMPS to power the amp in a car. 100W in a car should be OK.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#3 |
Banned
I have design SMPS +/- 35V, but the question is is this amplifier can handle 400wRMS suboofer or will be broken
#4 |
Did it Himself
It will be fine. Amps don't 'handle' speaker power, speakers 'handle' the power they are given.
You could have a 100W, 400W or 1000W speaker, as far as the amps is concerned as long as they are all the same impedance it doesn't care.
#5 |
1pair of MJ15003/4 will manage about 125W into 3ohm from +-35Vdc using +-30mF if you can keep them cool enough to survive. 2ohm loading can only reach 28degree phase angle @ about 170W.
regards Andrew T. |
#6 |
Andrew
I like your remark about keeping them cool enough to survive. One pair is best kept to 50W, and 2 pairs for 100W into 4 ohms. SandyK |
#7 |
2pair should be able to go to 180W into 2ohm @ 60degree phase angle and Tc<60degC. But 1ohm can only manage 25degree phase angle. It seems that 1pair could make a reasonable 4ohm amplifier but need blown sinks. 2pair would do as a 2ohm amplifier with a big unblown sink.
regards Andrew T. |
#8 |
Andrew
The trouble is that many people skimp on the size of the heatsinks, and don't use fans for higher power versions. SandyK |
| 4 each of MJ15003/MJ15004 | Stu | Swap Meet | 2 | 27th April 2008 08:34 AM |
| MJ15003/MJ15004 100mS SOA | Donk | Solid State | 2 | 15th January 2008 04:37 PM |
| Project 100W MJ15003 MJ15004 | Risto80 | Car Audio | 2 | 26th June 2007 02:41 PM |
| MJ15003's and MJ15004's For Sale | mbonham | Swap Meet | 5 | 7th December 2006 10:13 PM |
| Mj15003 Mj15004 | jackinnj | Swap Meet | 0 | 29th June 2003 10:19 PM |
| Page generated in 0.15170 seconds (47.06% PHP - 52.94% MySQL) with 10 queries |
