diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Solid State (http://www.diyaudio.com/forums/solid-state/)
-   -   can someone help me check this circuit? (http://www.diyaudio.com/forums/solid-state/104363-can-someone-help-me-check-circuit.html)
happyboy 29th June 2007 07:53 AM
2 Attachment(s)
Hi guys! Can you help me to check this circuit to see if is there any problem with it? It is just a simple circuit with a very simple CCS. It is supposingly to work in Class A mode most of the time. Thanks!
x-pro 29th June 2007 08:40 AM
2 Attachment(s)
CCS of this kind would be extremely unstable with temperature etc. Change it for a "normal" one. On the diagram it is set for about 1A current.
Cheers
Alex
happyboy 29th June 2007 09:33 AM
hi x-pro, thanks for your reply. I redrew the scematic in LTspice and simulated it. It works well but then it must be biased above 1.4A if not the some parts of the bottom half of the wave will be clipped off. Any idea why?
Also, must the 2N5550 be mounted together with the 2N3055 on the same heatsink? Cause its a TO-92 Package type.
Thanks!
AndrewT 29th June 2007 10:07 AM
I must be thick. I find trying to read that schematic with the voltage sources in unusual locatons very difficult to read.
You have posted a DC coupled amplifier.
The source resistance on the inverting input is 22k//100k=18k
the non-inverting sees 22k//0k0=0k0.!!!
That will guarantee an output offset.
The pre-amp or source that you finally connect instead of the idealised voltage source will controll the output offset by substituting a different source resistance. If it is DC blocked the non-inverting source resistance changes to 22k. oops the output offset has gone (unless you had zeroed it with a shorted input).
Do you plan to use a DC coupled pre-amp with a DC servo?
Have you tried moving the lower end of the load from the ground to the drain of M1? What does the simulation say? I may have this mixed up due to not properly understanding this schematic.
x-pro 29th June 2007 10:13 AM
You may change the CCS current by changing the value of R1 on the diagram (i.e. 0.4 Ohm for 1.5A) and if you need substantially more current, reducing R2 value. 2N5550 can be replaced by something like BD139 - however it dissipates less than 100mW and doesn't really need a heatsink.
Cheers
Alex
happyboy 29th June 2007 10:33 AM
2 Attachment(s)
Hi Andrew,
I am kind of lost when u mentioned about the output offset. Could you enlighten me further?
The simulation says that it would work without any DC offset so im kind of confused.
I plan to connect this directly to a CDP through a passive preamp.
Thanks!
happyboy 29th June 2007 10:36 AM
Cheers
Alex
Thanks for the info X-Pro!
x-pro 29th June 2007 10:41 AM
Hi Andrew,
the schematics is somewhat unusually drawn, however there is nothing wrong with it (IMHO) with the exception of the CCS. The offset due to the resistor imbalance on the inputs depends on the input currents of the opamp. For LT1001 in is only few nA and there is nothing to worry about - maximum offset it could create on the output would be less than 1mV anyway. For some opamps with >0.1uA of the input current that could be a problem, thought.
Cheers
Alex
happyboy 29th June 2007 10:44 AM
Hi Andrew,
Cheers
Alex
Sorry for the misconception, but the LT1001 is just there for me to do simulations. I intend to use AD826 in the final thing. Would it be a problem with the 826?
richie00boy 29th June 2007 10:52 AM
Can the AD826 survive on 24 volt rails?
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
