SAE 2400 amp needs help
Old 28th June 2007, 05:42 PM   #1
scm is offline scm  United States
Default SAE 2400 amp needs help
First, greetings to all...
I have an SAE 2400 that needs some work done to it.
I`ve had it since '84 and it has sat in a closet about 10 years now due to
some speaker wires that got shorted out and took out one of the channels. I think the output transistors might need replaced.
Should I just sell it on ebay as is ? or is it worth fixing ? Gotta admit I really like the beefy looks and the big analog meters..kinda miss staring at them while listening too.
If I decide to fix it, I don`t want a shop that will hold my parts for ransom with some huge repair bill.
I don`t mind paying for good parts and good work but i don`t like getting hosed either.
I wouldn`t mind a DIY attempt either but I`ve never built anything electronic before.
Any suggestions/opinions would be welcome.
Steve
Old 28th June 2007, 08:13 PM   #2
Jan Dupont is offline Jan Dupont  Denmark
Jan Dupont's Avatar
Send a message via MSN to Jan Dupont
Maybe this schematic can help you
http://www.audio-circuit.dk/Schematics/SAE_2400.pdf
Free Schematic and Service Manual downloads www.audio-circuit.dk, Spare time company (just for fun): www.dupont-audio.com
Old 28th June 2007, 08:51 PM   #3
Thanks Jan, I printed that out, could come in handy sometime.
Steve
Old 1st July 2007, 04:12 AM   #4
Anybody know what output transistors are needed to replace the factory ones?
Old 1st July 2007, 04:57 AM   #5
djk is offline djk
djk's Avatar
The designer recommends MJ21193/94.
Candidates for the Darwin Award should not read this author.
Old 1st July 2007, 12:23 PM   #6
Burnedfingers is offline Burnedfingers  United States
The correct way to rebuild this amplifier or any amplifier of that age is to replace all semiconductors and capacitors. In addition the main filter caps should be replaced. There are also a number of resistors that should be replaced because of their age and composition. Your looking at a amplifier that was manufactured around 1975 so its high time for it to get a face lift.
Old 1st July 2007, 06:59 PM   #7
burnedfingers...is what you suggest suitable for a novice ?
Where would I source out those parts?
Are there brands that would also be an improvement over the factory issue pieces ?
Old 2nd July 2007, 11:45 AM   #8
In my opinion...no.
I have seen too many basket cases from novices.
One example ....I repaired an amplifier that someone of very limited skill had worked on and managed to totally wreck a number of traces.
The traces aren't that thick and require the usage of proper desoldering equipment to minimize damage to the board.
There is a very good chance that the amplifier has been repaired one or more times in the past and this all takes a toll on things.
After all...you wouldn't take your car to a plumber would you?
Old 2nd July 2007, 11:08 PM   #9
Thanks guys...I`ve decided just to put it on Ebay as is.
SAE 2400 amp needs helpHide this!Advertise here!
Citronic PPX 2400 Neilgilbert Solid State 6 3rd June 2017 06:32 PM
nad 2400 thx amp schematic steven344 Solid State 4 25th July 2013 06:23 AM
mtx rt 2400 jtcarter40 Car Audio 1 7th March 2008 08:27 PM
Nad 2400 SillyCone Solid State 4 30th June 2007 09:32 PM
what to do with these caps: 2400 mfd, 450 VDC Jared Parts 12 11th October 2002 06:30 AM
Copyright ©1999-2017 diyAudio
