Well I dropped my old meter and need a new one. Does anyone have any recommendations on a good quality (i.e., accurate) DMM at a good value that has provisions to test for transistor hfe, preferably also with capacitance testing feature?
#2 |
This is what I use:
Specs: Function Specification Digits 3 1/2 DC Volts min. max. 1,000V AC Volts min. max. 700V DC Current min. max. 10A AC Current min. max. 10A Resistance min. max. 200 meg ohms Capacitance min. max. 20uF Frequency 20KHz +/- 1.5% or better Diode check HFE 1 ~ 1,000 Temperature Measurement min. -20 degrees C max. 1,000 degrees C http://www.elexp.biz/vir_my64.htm Yes, it is for VT students, but you should still be able to get it in NoVa.
Signature: Optional signature you may use to appear at bottom of your signatures. |
#3 |
I love my Fluke 87, however, my $30 craftsman DMM from the hardware store is great too.
44.36 |
#4 |
I just picked up one of these at the local surplus house : http://www.multimeterwarehouse.com/m810bf.htm
It works so well, I think I'll get a couple more for the shop and cars ... US$9 or less.
Over compression is a problem with modern CD recordings |
#5 |
Many DMMs even the cheap one do have the hFE function.
| amp testing | jackduckwort | Chip Amps | 0 | 16th March 2006 01:39 PM |
| testing FET | peter pkcc | Solid State | 2 | 16th June 2001 03:40 PM |
| Page generated in 0.07800 seconds (73.42% PHP - 26.58% MySQL) with 10 queries |
