Old 8th July 2007, 02:14 AM   #121
GK is offline GK  Australia
Originally posted by MJL21193
Hi Glen,
A completely solid attachment of the two metals might result in bending with temperature change - similar to a bi-metal bar in a thermistat.
Something to consider.
I'm interested in your design, but would like to try it on a smaller scale. 1Kw/channel is a tad high for my purposes.
Keep up the good work.
Yes I know, this is a pain. Aluminium has an expansion coefficient that痴 about 30% greater than that of copper.
I知 fooling around with the idea of using at thick sheet of copper, and building all the power output stages onto it as a sub assembly, which will be clamped to the aluminium heatsinks in favour of solid attachment.
Problem is that copper is very soft and malleable, so I値l need a pretty thick sheet (say 8mm or so). I知 getting the prices for the copper next week. I知 a bit fearful of what I知 going to hear though, so the copper idea is still pending.
I may be getting a little too esoteric with the design here
Old 8th July 2007, 03:41 AM   #122
Originally posted by Gold_xyz
Hi
It excuses my ignorance but it would be pleasant to also see a block diagram of the whole amplifier.
Thanks.
Here you go:
http://users.picknowl.com.au/~glenk/2000W.HTM
Old 8th July 2007, 10:21 AM   #123
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Originally posted by G.Kleinschmidt
http://users.picknowl.com.au/~glenk/CLASSB.HTM
Glen,
just curious, when will you be up for parole ?
Looks like Sponge Bob has killed another thread.
Old 8th July 2007, 10:27 AM   #124
Use for cooling this principle....
Old 8th July 2007, 12:53 PM   #125
Originally posted by jacco vermeulen
Glen,
Huh?
PCB for the +/-80V regulator is done.........Now onto the input/VAS PCB.........
Ta-da!
Old 8th July 2007, 01:10 PM   #126
Huh?
Another 256 Re's for the AB stage, makes a total of 496 you''ll be soldering.
I fail to see the advantage with such numbers involed, unless you'll spend a month in the slammer for masacring a kangaroo family.
What's the cost of a 1 watt metalfilmer in Bauxtralia ?
Old 8th July 2007, 01:18 PM   #127
darkfenriz's Avatar
http://users.picknowl.com.au/~glenk/CLASSA.HTM (+new one)
Hi, I am not sure about short circuit protection circuit, together with Hawksford's circuit it will saturate protection transistors when short circuit happens IMO. This is contrary to typical output stages, where active protection has proper Vce.
Old 8th July 2007, 01:20 PM   #128
I already metioned the advantage in a previous post. Perhaps you missed it.
Old 8th July 2007, 01:32 PM   #129
No! The protection transistors (as well as the EC circuit transistors) do not saturate on current limit. At the current limit of 64A, the 'error voltage' between the output and the end of the 750 ohm resistor clamped by the protection transistors will be in excess of 2V. The protection transistors clamp this voltage to maintain a constant load current - just like in a normal output stage.
Since the protection transistors clamp the 'error voltage', the EC circuit is inhibited also.
Glen
Old 8th July 2007, 01:45 PM   #130
Glen, look at " two pins " transistors, maybe something burn in your head...
Class D Vs Class I (Balanced Current Amplifier) rmsaudio Class D 28 29th September 2006 08:03 AM
Page generated in 0.11732 seconds (80.17% PHP - 19.83% MySQL) with 11 queries
Copyright ゥ1999-2012 diyAudio
