I've used this VAS in several production amplifiers around 1995-1997 and thought it would be useful to share this idea and to see if that arrangement have been used before - perhaps somebody would remember. The idea is to connect a common drain into a common-base stage, effectively creating a voltage to current convertor. Advantages are - good speed and linearity, completely symmetrical voltage and current limiting on the output, high OL gain in a 2 stage amplifier. On the first diagram here is a simplified configuration, on the second - a complete and known to work circuit with BJT output. However I've used this VAS with MOSFET output stage as well.
x-pro P.S. - transistor types on the second diagram I had to choose from available models to get the simulation to work. However BC550/BC556 for small signal, BD139/140 (Philips) in place of MJE15030/31 and 2SC2922/2SA1216 in the output were originally used. P-channel MOSFET could be ZVP3306, ZVP3310 or similar. |
#2 |
Looks good, neat constant phase circuit, very high bandwidth which would have to be tamed to meet Bode/Nyquist criteria, but is there really an advantage in using a Pmos, why not a bipolar?
How does it sound? Soundstage? Fine detail? Low distortion? Cheers, Hugh |
#3 | |
aka. long tail pair ?? |
#4 |
Adam is right; it mimics the LTP input stage, which is an emitter follower feeding a common base connection..... (though the second base 'moves' as its the inverting input)
Cheers, Hugh |
#5 | |
All the trouble I've ever been in started out as fun...... |
#6 | ||
Cheers Alex |
#7 | |
Cheers Alex |
#8 |
Greetings Alex,
You are a sleeper - an ex-Creek designer, I had not realised. No bloody wonder..... I always try to design the VAS with a naturally falling FR to help with compensation. To this end bootstraps are useful, so is the common emitter configuration. Your use of common base, driven in common source at a very high impedance gate (yielding very high gain for the input stage), would appear to give stratospheric top end, very little phase shift (good), and 120dB OLG into 10K (current dependent of course) is also very good. What distortion is introduced would be presumably low order, particularly H2/H3 from the mosfet as its current would vary very slightly. What more can be said? It's very good..... congratulations! Cheers, Hugh |
#9 | |
Thank you! Alex |
#10 |
Alex, in your circuit, I see C4 and C7 which are effectively capacitice shunts to ground, and then the same again with the C3+R13 network. What effect do these have on the OL gain response? Are these not heavy loads to tame the loop response?
Very interesting VAS topology BTW. |
| Aikido line stage - plus phono line stage | cjkpkg | Tubes / Valves | 1 | 22nd November 2008 09:50 PM |
| Output stage biasing, with the driver stage | andrew_whitham | Tubes / Valves | 0 | 19th May 2007 11:14 AM |
| Should I replace Scott 222C phono stage with Claret phono stage? | Bing Yang | Analogue Source | 0 | 22nd August 2005 06:41 AM |
| Line stage preamp, based on SY's "Heretical Unity gain line stage" | Danko | Tubes / Valves | 23 | 18th July 2005 04:07 AM |
| Dsd without D/A stage.... | kyrochan | Digital Source | 15 | 30th March 2005 04:36 PM |
| Page generated in 0.13507 seconds (78.00% PHP - 22.00% MySQL) with 11 queries |
