I blew the 3 of the 4 speaker out fuses with my Polk SDA speakers when hooking it up blindly. I realized my mistake, but wanted to finish my listening session. So I stuck 2 15a, and a 20a fuse in. Fix the speaker wiring. Turned it on, and poof. I looked for damage, and found none. So I busted out my mm found power on the soft start board. Unplugged it. Started testing resistors. The big 20watt 4.7uf was open. Took a hammer to it. Found the burnt spot. I am scared to just replace the resistor( I have 2 10ohm 10watt resistors). I don't want to blow anything else. What caused the resistor to blow after installing the speaker fuses?
Should I raplace the rail fuses, and give it a go with 5ampers instead of 10ampers? Thanks Ben |
#2 |
Hi Ben,
Sorry to hear about your problems, but I think you need to take it to a professional before you do more damage to it, or yourself. regards
Greg Erskine |
#3 |
Polk SDA speakers will blow up mono-bloc and bridge output amplifiers.
This includes dual-mono amps like the Adcom GFA555.
Candidates for the Darwin Award should not read this author. |
#4 | |
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#5 |
Killed this thread, and started another. Due to lack of sleep I rated a 4.7 ohm resitor a 4.7uf. I gotta watch stuff like that
| PCB Relay for ESP soft start board | wytco0 | Parts | 6 | 8th August 2009 08:23 AM |
| Adcom GFA-585 Blown 20w 4.7ohm on soft start board | ben62670 | Solid State | 133 | 31st January 2009 09:08 PM |
| B+ soft start | Gluca | Tubes / Valves | 2 | 3rd September 2007 01:04 PM |
| Soft start & Soft Switch circuit: can anybody help? | m.parigi | Solid State | 95 | 22nd August 2005 03:32 PM |
| Commercial Soft Start board | wytco0 | Parts | 0 | 5th August 2005 04:26 PM |
| Page generated in 0.08295 seconds (70.16% PHP - 29.84% MySQL) with 10 queries |
