Help with Tranny Wireing. - diyAudio
Old 28th January 2003, 02:28 AM   #1
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
Default Help with Tranny Wireing.
Ok i bought 2 brand new transformers from Peter Daniel They didnt come with Wireing diagram or any thing. they have 7 wires
black
white
green with yellow stripe
2 brown
2 blue
can any one tell me what they are.
here is my guess
2 brow = one set of secondarys
2 blue = another set. of secondarys
blacn and white is ac in.
and green is the center tap
Old 28th January 2003, 02:45 AM   #2
seangoesbonk's Avatar
I would guess that the Black & White are Hot & Neutral, the Blues are one secondary, the Browns are another secondary. I think the Green w/ Yellow should be connected to the Earth coming from the mains???
The best thing would be to ask P.D. or has anyone reading this bought a tranny from VM that came with a wiring diagram?(It would likely be the same...)
My girlfriend's sub is bigger than mine...
Old 28th January 2003, 02:48 AM   #3
Banned
i did ask P.D. You would think he would know but he didn't he sujested emailing victoria magnetic's. I may just do so.
Old 28th January 2003, 02:53 AM   #4
Emailing VM is probably the safest way to go. (You don't want to damage the transformer). If you give them the model # off the tranny, they should be able to help you out.
Old 28th January 2003, 02:58 AM   #5
fcel is offline fcel  United States
Email John (john@victoriamagnetics.com) tonight and you'll get your answer tomorrow morning.
Email John the picture that you posted here. He's familiar with what we diyers are doing with those transformer.
Old 28th January 2003, 03:22 AM   #6
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
fcel,
I thought you were using the same transformer on your Aleph2.
Anyway, this is just a simple toroid and the previous suggestions were right on the mark. The green/yellow wire is shield and should be connected to the ground. The other wires are easily identified with a meter. The highest impedance would be for primary. THe other two are secondaries. The short piece of a jacket is to mark the same phase on secondaries, I guess.
No need to trouble John.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 28th January 2003, 05:48 AM   #7
My VM 1kva transformer has only one set of secondary. White/Black is Primary. Blue/Brown/Blue are secondary where Brown is secondary center tap. I guess JasonL can figure out the other set of secondary wiring.
Old 28th January 2003, 05:51 AM   #8
Banned
did i tell you how hevy they are. : O ( my amps are going to weigh like 100lbs each. : O (
Help with some speaker wireing please.... Minion Multi-Way 5 7th December 2008 02:01 AM
Please Help With Wireing My Cab!!! Dtorre Instruments and Amps 5 19th July 2007 10:27 AM
DIY attenuator (was silver wireing) Magura Parts 7 19th March 2004 03:05 AM
Shielded cable for internal amp wireing: where do I connect the shield? Bricolo Parts 11 26th June 2003 02:26 AM
Atx computer powersupply Wireing schematic jleaman Digital Source 8 15th August 2002 10:59 PM
Copyright ©1999-2017 diyAudio
