which transistors are blowing?.. is it the driver or output stage?..
for the output stage,check those 2 IN4004 bias on 2 driver transistors.. it may be open..
and those vrail are too high that could burn your amp.. this design are more in our country and i really dont like it..
i have this amp before and keeps me in trouble..you may refered to the other design made by our fellows here.. try those leach amp and others..
try this..this is simple and easy to build..
Re: i am interested too
http://marcusgun.com/elektronik.html
http://www.diyaudio.com/forums/showthread.php?s=&postid=51642#post51642
sakis said:looks very simple and powerfull ...this m250 has anyone built this ??? can you tell more about performance ???
- power amplifier 400w @ 4 ohms
