Rebuilt Quad405 Problems
Old 17th July 2007, 10:21 AM   #11
Thomo is offline Thomo  United Kingdom
Thomo's Avatar
My Quad has been singing nicely for quite a while now, and I'm fairly pleased with it.
I have a question though, is it possible to change C5 to a larger value, higher quality cap?
Lee.
Old 17th July 2007, 10:42 AM   #12
MarkMcK is offline MarkMcK  United States
Question for anyone knowing the history of the Quad 405. When first introduced it boasted innovative circuit design. I believe they called it current dumping.
The schematic posted here, however, is an old fashioned quasi complementary design. What happened to all the innovation? When did Quad abandon it?
Mark
Old 17th July 2007, 11:14 AM   #13
Ouroboros is offline Ouroboros  England
Ouroboros's Avatar
Quad used NPN output devices for robustness (and cost I guess). The 'Current Dumping' scheme means that the lack of linearity of the upper and lower totem-pole transistors isn't a problem, so you can use a quasi-comp output without any performance issues.
Old 18th July 2007, 10:23 PM   #14
405man is offline 405man  Scotland
The Quad 405 is an error canceling amplifier and uses a reactive bridge to combine the output of a class A stage with an unbiased output stage. If you look at the last page here
http://www.dc-daylight.ltd.uk/Valve-...-Evolution.pdf
It is easier to see the configuration than in the original Quad schematic
This is a link to an original article from Quad
http://quad405.com/currentdumping.pdf
and this one to further discussion about this inovative design
http://quad405.com/jaes.pdf
Stuart
Old 19th July 2007, 08:02 AM   #15
dcd is offline dcd  United Kingdom
Alex mm
You appear to have copied one of the features of the 405 PCB accurately - you have an electrolytic capacitor along side the R30/R31
L2 should not be 3.3uH - If you are aiming for accuracy and as you now have the bridge implemented correctly you should make it the calculated value.
The original design articles show how the bridge is derived using resistors and everyone now believes that the use of an inductor L2 is simply to reduce power losses when in fact it could be a 0.3-0.5R resistor with little loss but for the fact that it is fitted to prevent switching spikes from getting to the output and as such it is best that L2 (and all the inductors) are a bit lossy to prevent ringing.
Keith
DCD
Old 4th September 2007, 09:26 PM   #16
alex mm is offline alex mm  Romania
alex mm's Avatar
Default QUAD with MOSFET output transistors
....Hi
another version of QUAD http://i15.tinypic.com/6hcsgg4.jpg and PCB http://i15.tinypic.com/63ltm6b.jpg .Amplifier will bee tested this weekend ,i hope
Old 5th September 2007, 06:54 AM   #17
geminni is offline geminni  Serbia
Mosfet for output? Can't wait for results!
Old 5th September 2007, 09:32 AM   #18
Do you have a schematic
Stuart
Old 5th September 2007, 10:37 AM   #19
tvicol is offline tvicol  Romania
tvicol's Avatar
Rebuilt Quad405 Problems Rebuilt Quad405 Problems
Default Quad 405 Mos-fet
This version was made at Keith suggestion. Thanks Keith !
Schematic vas posted on a Romanian forum.
Here is the link
QUAD 405 Reborn MOS-FET output
We are currently testing, so this is not final.
You are invited to comment this implementation.
Tibi
Rebuilt Quad405 ProblemsHide this!Advertise here!
QUASAR a QUAD405 reborn design tvicol Solid State 207 19th October 2015 03:56 PM
Help: inductances in original Quad405. La Mer Solid State 13 8th December 2008 03:58 PM
question about quad405. ary Solid State 8 25th July 2005 01:44 AM
1st post: Where to get KEF C75 rebuilt? TIA ClarkStarr Multi-Way 1 22nd July 2005 12:11 PM
Help Please-Distortion in Rebuilt Amp hifileslie Solid State 1 7th August 2002 08:31 PM
Copyright ©1999-2017 diyAudio
