just obtained a harmer+simmons SM600 switch mode power rectifier used for batt recharging purposes. The specs says Vout=54.5Vdc and Iout=12Adc. would this unit be of any good to power an amp of choice?
not sure what sort of amp class would that rectifier module be usefull. seems that all class A/AB and D design seems to want like +35V,0,-35V versus this one at +54V,0 Can some help here? thks |
#2 |
Did it Himself
Most amps can be converted for use on single power rails, with a few modifications and the addition of an output capacitor. Class-d modules you might struggle with though.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#3 |
would there be a schematic i could refer to do a single rail amp then? or would it be better to try and split the current 54.5V,0 to say +25V,0,-25V........how do i do that... the ps does not seem to have the usual mains transfo and the bridge rectifier.
| 1500W RMS Class D PCB - which Class D Driver Chip is it ? | mosfetsound | Class D | 11 | 1st April 2011 11:17 AM |
| Can a Class AB PP amp be said to be operating in Class A at low signal levels? | ray_moth | Tubes / Valves | 19 | 23rd January 2009 07:52 PM |
| How about a round-up of Class A kit power amps, or collectable vintage class A? | Brisso57 | Solid State | 4 | 14th February 2007 10:30 AM |
| Page generated in 0.07186 seconds (67.97% PHP - 32.03% MySQL) with 10 queries |
