I have 8 MUR3060 and plan to build a 100Wx2 amplifier. Is this device a better choice over the KBPC3510 bridge rectifier?
MUR3060 is the high current version of MUR860. (30A, 600V) and this device has 3 legs which are two diodes in parrallel. |
#2 |
Generally these fast devices have a much lower surge rating than the KBPC3510. Look at this parameter in their data sheets. If you have a lot of capacitance in the PSU, it may be worthwhile using some kind of surge limiter to reduce current for a short period on switchon. Otherwise the fast devices may fail, This has been reported in several forum postings.
SandyK |
#3 |
Is there any classic surge limiting circuit for the PSU if the ripple cap is over 10000uF ?
#4 |
Did it Himself
Those diodes will be more than enough for a power amplifier of the power you want, without any surge protection. I run 20A diodes in a 1x400W system that I use for parties and have never had a problem.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#5 |
A 6A general purpose rectifier
http://www.onsemi.com/pub/Collateral/MR750-D.PDF has a 60hz surge current of 400A, the MUR3060 is only 150A (per leg). A 2R5 inrush current limiter http://www.cantherm.com/products/the...therm_mf72.pdf works well in most audio amplifier applications. The 2R5 model is rated for 5A and less than 0R095 at that current. In very large amplifiers (above 100W/ch) you may want to short it out with a relay after a short delay. I have lost 400A surge rectifiers with caps as small as 27,000µF, it is also dependant on the resistance in your transformer windings (bigger transformers are harder on rectifiers).
Candidates for the Darwin Award should not read this author. |
#6 | |
I've done this before- Soft Start Circuit Implemented in Krell Clone
My DIY audio projects- PartTimeProjects.com. |
| Bridge rectifier vs Full wave rectifier | hilbert_mostert | Tubes / Valves | 4 | 28th April 2009 08:26 PM |
| 4 rfb-02 rectifier bridge pcb's | BeerCan | Swap Meet | 1 | 23rd July 2008 07:07 PM |
| Location of rectifier bridge? | ex192 | Chip Amps | 3 | 8th May 2005 03:40 PM |
| Integrated Rectifier Bridge VS Rectifier Diodes | Sci | Chip Amps | 11 | 16th July 2004 02:43 PM |
| Bridge Rectifier | thylantyr | Solid State | 2 | 21st August 2003 09:11 PM |
| Page generated in 0.10901 seconds (70.07% PHP - 29.93% MySQL) with 11 queries |
