Old 14th June 2007, 11:48 AM   #1
Default Amplifier N-FET
Hello, i have a problem for experts
I simulate this schematic into Orcad and it worked perfectly well, but when I build it fizicly i'm having a few problems when i rich up the IN volume level. I put the osciloscope on exit and when i'm increasing the volume the shape of the sin wave is becomeing strange.
If you cand recorect the schematic, please, with less modifications possible, because the PCB is allready made and cannot admit to many modifications, i mean I want if you can to recorect the actual value of the components(R,C, so on)
Please post(draw on to the original schematic) the modified schematic because if not is difficult to understand in words the new improvements you made.
Thank you very much.
image scop:
http://img176.imageshack.us/img176/9...0resizepb0.jpg
http://img176.imageshack.us/img176/3...6resizefk6.jpg
Old 14th June 2007, 12:07 PM   #2
Did it Himself
richie00boy's Avatar
That is oscillation. It could be your PCB just as well as your schematic.
D9 should not be there, but I don't think it is the cause of your problem.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 14th June 2007, 12:09 PM   #3
x-pro is offline x-pro  United Kingdom
x-pro's Avatar
On a first glance:
Increase gate resistors to 100 Ohm, move R33, 34, 35 into the sources of M4-M6, remove C10, perhaps connect (if required) a small capacitor (2-10 pF) between collector of Q3 and bases of Q8/Q2. You may need to reduce the amount of feedback - I would think the gain of 30-50 is more appropriate in this kind of configuration.
Cheers
x-pro
Old 14th June 2007, 12:20 PM   #4
roender is offline roender  Romania
roender's Avatar
Make C10 as small as possible, the right value is one which produce nice square wave output, without ringing, and no oscillation
BTW, nice design!
Old 14th June 2007, 05:20 PM   #5
without c10
pictures-scop
Old 14th June 2007, 06:30 PM   #6
Old 14th June 2007, 08:10 PM   #7
The one and only
Nelson Pass's Avatar
start with x-pro's advice, and just for grins, also try removing D6.
Old 14th June 2007, 08:52 PM   #8
x-pro's Avatar
On top of what I've said earlier one more question: what are your power supply arrangements for the circuit? Is there sufficient decoupling on the supplies?
Cheers
x-pro
Old 14th June 2007, 09:12 PM   #9
the power supply & all aranjament
http://img159.imageshack.us/img159/5725/img6343rt2.jpg
+/-42v at 12v car battery
I will try all changes and i'll post results.
Thank very much all of you!
Old 16th June 2007, 05:11 AM   #10
Default Instability in Amplifier
I have seen such behavior in simulatons before. It is very likely that some component parameters in the actual circuit are different from those assumed in the simulation.
I would start by seeing if the observed effects in the real circuit can be replicated in simulation by adjusting simulaton parameters. For starters, you might consider adjusting down the idle currents in the simulation VAS stage. The waveform you posted does not look like a classical case of HF oscillaton as much as a predriver or driver stage running out of current. If you are able to replicate the problem in simulaton then it should not be too difficult to determine a fix.
Hope this helps.
JCM
Wanted: DIY amplifier builder with experience. I need a 0.7 ohm stable amplifier Audiophilenoob Swap Meet 34 16th May 2005 11:58 PM
Questions about how to decrease the PASS A-40 amplifier into a class AB amplifier. novtango Pass Labs 2 21st October 2002 01:50 AM
Page generated in 0.10279 seconds (76.77% PHP - 23.23% MySQL) with 10 queries
