Hello, I have a c-audio ST600 and it has mosfets burn.It used 2sk1058 and 2sj162.I have buy news this and I have tested before to mount and all are in shortcircuit beware S and D and I do not mount because I do not understand.I have make a tester circuit for mosfets and it,s the same.Why?Can anybody help me ?Thanks.I have send circuit test that I have used.
#2 |
These transistors have a built in protection diode from S to D, so that is probably what you measure as a short circuit.
#3 |
Hello, I know that it have a internal diode but I have tested in the 2 direcctions possible and is in short circuit.Thanks for answer
#4 |
Did it Himself
Make sure you connect gate to source while doing the resistance test. The voltage on your hands will turn the MOSFET on. You might have even damaged them already with this voltage.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#5 |
I'm pretty sure those mosfets also have a gate protection diode, so they should be OK.
#6 |
Yes, they have a gate protection diode. So they probably are OK. However, if you measure from gate to another terminal with a voltmeter, it will either turn the device fully on (or fully off), depending on the polarity you applied.
To get a better reading, discharge the gate by touching the gate and one of the other terminals with your fingers. This will bleed off the residual charge and allow an accurate reading. Good luck. |
#7 |
Hello, I know that it have a diode and I have tested in 2 polarity and is in shortcircuit. I have discharge with all posibilities and it,s in shortcircuit. It,s possible damage with fingers? All news mosfets are damage. I do not understand.Thanks
#8 |
hi there,
are these new parts you are testing? these transistors are fairly rugged i would not expect that you have blown them with static. have a look at this for testing http://www.4qdtec.com/mostest.html i think he is talking about n type devices in this example, for p type reverse the leads. also i find that most multimeters will work on ohms range with this test regards bob
regards bob |
#9 |
rafelo
If you are going to be working with many mosfets and/or jfets I recommend you buy a semiconductor tester. They cost around us$100 and will recognise and test most types of transistor and fet. They use a few miliamps ( usually 3ma ) to test with and will not damage any of the parts. You can also use them to match parts for most operations. Don |
| P101 Problem. Bad MOSFETs??? | vinyvamos | Solid State | 4 | 13th January 2008 01:46 PM |
| n/p Mosfets vs depletion mod mosfets | marcello7x | Car Audio | 6 | 4th October 2006 05:01 AM |
| mosfets, why the big ones | jjacks4x | Pass Labs | 19 | 19th December 2002 09:19 PM |
| New to mosfets, need help! | Duo | Solid State | 18 | 19th December 2002 06:47 PM |
| hmm.. help with mosfets | Colt45 | Solid State | 5 | 27th August 2002 07:08 AM |
| Page generated in 0.10437 seconds (78.00% PHP - 22.00% MySQL) with 11 queries |
