has anybody ever thought about running sense lines to the speakers, much the same way is done with open frame power supplies? the sense line would be the amplifier feedback, and actually include the speaker wiring and it's losses in the feedback loop. of course, there would have to be some way to default the feedback in case one forgets to connect the sense line, and end up with open loop gain. has this been tried before, or is it more trouble than it's worth?
Vintage Audio and Pro-Audio repair ampz(removethis)@sohonet.net spammer trap: http://www1284177414881.v-dc.net/ |
#2 |
I remember reading about something similar to this. The greatest reason why it caught no success was - if I remember right - the need for a "special" speaker cable (one with more than two conductors).
#3 |
I have also had that idea, as I am sure many, many others have. I think the main problem is that the open loop frequency response of the amplifier now depends on the speaker cable. That could be very dangerous unless using a speaker cable with known characteristics and making sure the amp is stable with that cable. I also think, that almost regardless of what speaker cable we use, we should only take low frequency feedback from the speaker terminals, and have a high-frequency bypass from the amp output.
#4 | |
#5 |
You won't gain anything meaningful in my opinion. You'll improve output impedance, but not by an significant fraction of loudspeaker resistance. The stability issue can be overcome by making sure the ouput side of Cf goes directly to the output of the amplifier.
You'll find a lot more information about this idea with regard to power supplies if you search for "Kelvin Sensing". |
#6 |
Was done over 30 years ago by Crown, Kenwood, Sansui, and others.
None of those do it now, draw your own conclusion.
Candidates for the Darwin Award should not read this author. |
#7 |
i figured as much...... and using it for self-powered speakers is kind of redundant, since the speaker wires are usually very short anyway..... with power supplies, the required bandwidth only needs to be a few hundred hertz, since the regulator only has to deal with DC and the first few harmonics of the power line frequency...... sounds like it's more trouble than it's worth.....
#8 | |
Regards Charles |
#9 |
The power amp should be in monobloc form beside the LS to cut out all of the LS cable induced problems anyway.
Cheers ........ Graham. |
| A75 alternate mosfets questions and more | jupiterjune | Pass Labs | 11 | 4th November 2010 02:23 AM |
| Feedback scheme. | jane | Tubes / Valves | 9 | 17th February 2008 10:00 AM |
| Alternate grill ideas | sbrunkow | Multi-Way | 2 | 9th December 2006 05:16 PM |
| Alternate spice models | lndm | Tubes / Valves | 5 | 15th August 2006 12:37 AM |
| Alternate PWM modulation schemes | ClassDunce | Class D | 6 | 18th November 2004 10:45 PM |
| Page generated in 0.12647 seconds (73.51% PHP - 26.49% MySQL) with 10 queries |
