Old 10th June 2007, 07:26 PM   #1
Send a message via AIM to Stormrider Send a message via MSN to Stormrider
Default Lighthouse electric amplifier opinions.
http://www.lh-electric.4t.com/projects/100W-RE.htm
I found this site through a google search this afternoon. Anyone care to give there opinions on this circuit? Is it actually capable of 100 watts into 4R? Quality? For 30$ a channel it looks like pretty good deal.
Thanks.
Old 10th June 2007, 08:08 PM   #2
tinitus is offline tinitus  Europe
Its 100watt into 4ohm load and 60watt into 8ohm, sounds realistic
The 30watt version might very well double its output from 30watt to 60watt into 4ohm
I could be suspicious about if these transistors are tough enough to manage long time hard abuse into 4ohm - but theres a limiter built in and it will probably benefit from big heatsinks
Opinions on the Conrad Johnson MV75 amplifier please. Original Burnedfingers Tubes / Valves 9 4th June 2010 09:54 PM
Opinions on Panther amplifier design olev Solid State 3 4th April 2009 10:23 PM
Opinions from amplifier analysers on these amp circuits georgehifi Solid State 10 11th April 2007 02:56 AM
Any opinions on KITSRUS amplifier kits mokus Solid State 11 25th February 2004 09:50 PM
Page generated in 0.07111 seconds (67.22% PHP - 32.78% MySQL) with 10 queries
