Hi, this is my first post sorry for my poor english
so, I just built a new ampli mosfet like in the picture but when turn on the power the mosfet burn in few seconds.... why?!!?!? any suggestion?!??! |
#2 |
Ciao ciccio!
Where are you supposed to connect the power supply to the amplifier? From the diagram it's not clear. I think you should connect the positive end of the power supply (maybe 20-25Vdc) to the drain of the upper power transistor, and the negative end to the drain of the lower power transistor. Also make sure about the pinout of the power mosfets and the operational amplifier. Just for testing, you can also put a 1000uF 50V capacitor in series with the load (the 8ohm power resistor or a loudspeaker), just in case there is serious voltage offset at the output due to a wiring error. BTW, I don't think it's a great design. You can't drive power mosfets with an output impedance of 10k (between the output of the opamp and the power mosfet's gate). |
#3 |
I agree, the mosfets are too much of a load for the opamp. There is probably some oscillation there.
Maybe you should look at http://www.wnaudio.com/amos100.pdf |
#4 | |
ciao, yes, the power supply is 22,5v from a torroidal transformer and 2 caps 4700mF/63vl I have only a tester... ![]() the pinout of the mosfet are correct.... about the design; I dont know! you think is not good??? thanks ciccio. |
#5 | |
ok I agree... and for this reason I want change all my project with a new one!!! I think the "classic" project are always the best! any suggestion are welcome. |
#6 | |
The Mosfet output stage is drived by the open loop output impedance of the TL 071 Op amp, usually around 100 Ohms, in series with the 100 uF capacitors. As the Mosfets at DC and low frequencies have a near infinite input impedance , the 10 K Ohms are perfectly adequate , at high frequencies when the input capacitance come into play , the 100 uF capacitor bypass the 10 K resistor. But certanly, the circuit maybe upgraded with a bipolar driver before the output Mos-Fets. Arrivederci
Jorge |
#7 |
opsss... I forget the picture...
#8 | |
Ciccio, you should also check the pinout of the TL431, just in case the drawing was wrong. Did you set the 47k trimmer? How much quiescent current you wanted to pass in the output stage? I hope you're using big heatsinks if you plan deep class A. Why don't you take a look at Elliott's site, for projects? http://sound.westhost.com/projects-1.htm |
#9 | |
ciao Giaime, the pinout of TL431 is ok! I have only read the volt... is about 2.3v and -12v the current? still not cheked... the heatsinks... mhhh... I made the test without....maibe for this reason the mosfet always burn! anyway maybe is better the new solution!!! what you think?!?! ciao. |
#10 |
The FETs will burn up if the bias is not set.
Without a heatsink, the FETs will burn up even if the bias is set. The design of this amp looks marginal.
Candidates for the Darwin Award should not read this author. |
| use a PA ampli for sub | cld1354 | Multi-Way | 29 | 29th June 2009 09:39 AM |
| ampli mosfet irf 540 + irf9540 | xcicc | Solid State | 24 | 20th March 2009 12:10 AM |
| my new ampli mosfet | xcicc | Solid State | 23 | 12th August 2008 02:44 PM |
| Matching IRF530 for a buffer, some results, but I need advice | justblair | Parts | 4 | 10th July 2008 02:44 AM |
| Page generated in 0.12738 seconds (78.05% PHP - 21.95% MySQL) with 11 queries |
