Switching power supply for a power amp ? - Page 2 - diyAudio
Old 11th January 2008, 02:06 PM   #11
dinu is offline dinu  United States
The limitations imposed by size and cost of large power supplies have also led me to look at SMPS for alternatives to linear PSU's. I was interested in this article http://www.stereophile.com/solidpoweramps/306chord/
about the Chord 14000 that apparently uses such supplies for what is far more amp than I can ever imagine needing. Here's a quote:
AC from the wall is filtered, then rectified to DC—some 300–350V worth—and stored in a bank of high-voltage capacitors. At this point, the current is still connected to the mains. It is then "chopped," using high-voltage MOSFETs running at 80kHz (footnote 2). From there, the resulting high-frequency waveform is sent to a custom-made ceramic-core transformer wound with multistrand Litz wire. As the size of a transformer decreases as operating frequencies increase, only a small transformer is required to re-rectify the 80kHz waveform. At the transformer's output a bank of very fast rectifiers, a small coil, and small capacitors convert the waveform back to DC for the final time, when the electricity is handed off to Chord's Dynamic Coupling system prior to being stored in a final bank of capacitors.
Even if I never attempt such a peoject I would like to know more about this and how it works. I guess that approach doesn't bring the cost down too much since these things still cost $75k/pair.
"make a move and plead the fifth cause you can't plead the first"
Old 11th January 2008, 05:13 PM   #12
ilimzn is online now ilimzn  Croatia
Originally posted by gaetan8888
Hi
How about this schematic ?
This schematic is slightly off, I'd say. First of all, it shows something called a flyback converter, for these it is not possible to have full-wave rectification at the output, so you can't use a CT winding as shown. It also does not show the polarity, or if you will, winding direction for the windings, which is crucial. A similar schematic could be used to construct a 'forward' converter, with full wave rectification, but I don't see that in the schematic.
Also, it neglects to mention that both input and output filter caps need to be low ESR for SMPS applications, normal ones will literally cook themselves to a quick death.
As far as SMPS for power amps, it has been done for a long time - first I know of were some Sony amps ion the late 70's / early 80's, with fully discrete SMPS. I have one of those and it works just fine, but then, for EMI/RFI purposes, the supply itself is enclosed in an aluminium 'brick'.
Old 11th January 2008, 07:06 PM   #13
ekaerin is offline ekaerin  Sweden
ekaerin's Avatar
Hi all,
I could be wrong but I think LAB gruppen used to have a flyback supply in their amps.
A teacup size pot-core that could have given the most rugged SMPS designer nightmares for life.
An SMPS for an audio amp is not necessarily cheaper nor smaller than a "linear" supply,
considering the overload capacity of a conventional X-former.
I was planning a 200W SMPS for an active speakers but I ended up with a 160W
standard toroidal instead.
However, going to higher power, then the SMPS probably start to pay off.
All control circuits, housekeeping supply etc starts to become less significant compared to the power stage, which is already small compared
to a "linear supply", as the power goes up.
Another reason to go SMPS is the formfactor. I can't see any problem
to fit a 1kW+ supply in a 1HE height case. Might need a fan though.
Regards / Mattias
Old 12th January 2008, 10:37 AM   #14
nikwal is offline nikwal  Sweden
I use vicor modules
I guess it's not the cheapest solution though. But they work very good for me..
It's important in any case to screen the smps even if it is vicor modules..
http://dsl.mine.nu/galleri/misc/amp2/DSC01027.JPG
http://dsl.mine.nu/galleri/misc/miniamp/mini5.jpg
(amp boards are my own construction of course if anyone wonders what's in there)
Old 12th January 2008, 10:46 AM   #15
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
Originally posted by nikwal
I use vicor modules
Can't seem to find any above 95 volts out. Any links please?
Old 12th January 2008, 10:53 AM   #16
Use two.. or four.. I have four.. two for each channel. but not 95Volt's , what could I do with 95voltsm that would be a PA system not home amp..
and ilimzn, there must be a better schematic than that one?.. 80khz seems a little low for audiophile but i could be wrong of course, also I would like to se real opto feedback and secondary + and - windings.
In theory it should'nt be too hard putting something that works togeather but to get it small and good and safe could be a problem i guess, I dont want my amp go KABOOM in the middle of the night because I forgot to turn the amp off hehe..
http://dsl.mine.nu (very enironmental friendly 5watt damn small linux server made from a compaq t1010 terminal)..
Old 12th January 2008, 11:33 AM   #17
dhaen's Avatar
Thanks I forgot which forum I was in. All this low voltage stuff ...
Old 12th January 2008, 12:42 PM   #18
ekaerin's Avatar
The Vicors are neat but as said need some input output lytics filtering etc. Not cheap but nice and with approved isolation barrier.
However, stacking modules for higher voltages may need some precaution if not stated in the data sheet.
If you're going to current limit one module could reverse the output of the other thru the load.
Also secondary side Y-caps going to GND may experience a too high voltage then designed for.
Regards / Mattias
Split Voltage Switching Power Supply for Power Amp vectorplane Swap Meet 2 23rd April 2011 11:48 PM
Switching Power supply allanon77 Solid State 31 25th June 2010 06:41 AM
K6 Switching Power Supply microsim444 Swap Meet 0 23rd November 2008 09:21 AM
Switching power supply Thomas B Pass Labs 15 9th December 2002 10:28 PM
switching power supply? partyjups Solid State 1 6th October 2001 12:44 PM
Copyright ©1999-2017 diyAudio
