#11 |
thanks for that tip, but sadly it's no good.
I can't even ping that IP, and any attempt to resolve the URL gives me a completely different ( and wrong ) IP. ...oh and using another browser (Opera) doesn't work either. Ray |
#12 |
if you can't ping the IP then it won't matter which browser you
use and it isn't the DNS server that causing the problem either. Can you reach other sites in the same domain? Try for instance to ping 203.202.24.61 instead. I don't know what this IP is, but it worked fine to ping it from my computer. |
#13 | |
I would say DNS problems or even client problems. Even trying a different browser is a good idea since IE6 sometimes stops working for inexplicable reasons but I see you tried Opera. Netscape, despite any other issues, ususally seems to stay working when IE stops. As usual clear your browser cache as step 1. Sorry for the computer dravel.
UrSv Those who say it can't be done should not stop those who are doing it. |
#14 | |
server without problems, so it is obviously not blocked to ping requests. |
#15 |
So then that implies local (ISP not client side) DNS problems to me at least unless it is client problems.
#16 | |
number directly, shouldn't it? |
#17 |
hmm, using the IP directly reports an error from the web site - it actually seems to come from the correct site so I assume my problem is due to local DNS problems.
anyway, enough off topic banter, I'm sure you'd prefer to return to the normal programming.... ray |
#18 | |
And yes, I volunteer to stay off further computer stuf for a while.
| Regulated power supply | meanman1964 | Everything Else | 13 | 9th April 2007 02:50 AM |
| Regulated DC power supply | Panicos K | Power Supplies | 11 | 21st October 2006 12:32 AM |
| Regulated power supply | crissty | Chip Amps | 23 | 2nd September 2005 04:18 AM |
| Using regulated power supply for A3 | kirc | Pass Labs | 4 | 25th October 2002 12:09 PM |
| regulated power supply | yugaaa | Solid State | 3 | 17th June 2002 06:22 PM |
| Page generated in 0.13556 seconds (70.51% PHP - 29.49% MySQL) with 11 queries |
