Old 6th June 2007, 10:55 AM   #1
Default cap conditioning question
Hello,
I broke in some Black Gate and PP caps then had to leave the project for a couple of months. Now I'm getting back to it and would like to know if they should be conditioned again, or is once enough?
Also, do oil filled motor run caps benefit from this process?
TIA
Old 6th June 2007, 11:08 AM   #2
Did it Himself
richie00boy's Avatar
Breaking them in is a waste of their life IMO, they only have a certain number of hours lifetime. Just use the equipment and they will break in on their own, while you get the benefit of listening to music
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 6th June 2007, 11:11 AM   #3
Hartono is offline Hartono  Indonesia
The PP caps (mostly) only need 1 time break in.
I gave up with Blackgate long time ago. Break in took ages , if you don't use your Blackgate it will need another break in again.
Old 6th June 2007, 07:35 PM   #4
impsick is offline impsick  United States
impsick's Avatar
man i read it all over but dont think i've seen a logical answer or reason why. What exactly is breaking in caps? I mean they are built to do what they do, so what actually happens to the cap when it is broken in? Something physically changes internally? An internal chemical reaction? What?
I guess for me to understand this breaking in "theory" the cap would have to change internally, physically or chemically.
ps not trying to start something crazy debate. just want to know what happens to the cap when it is considered broken in.
"Nothing happens for a reason. There are just reasons why things happen." Quote me on that. http://stores.ebay.com/AudioGrade?_rdc=1
Old 6th June 2007, 07:54 PM   #5
in electrolytic caps, it got something to do with it's structure and chemical I guess. In case you never heard it, try panasonic FC in your power supply, listen to the difference after 15 minutes of operation.
in plastic caps, I think it's mostly healing of the dielectric.
Old 6th June 2007, 08:43 PM   #6
impsick's Avatar
oh ok, i will check that out. i actually have a power supply using FC's. If i can hear it, I'll believe it!!!
Old 6th June 2007, 08:46 PM   #7
I mean new unused FC !!!!!
put in the power supply and wait 15 minutes after operation.
Old 6th June 2007, 08:49 PM   #8
impsick's Avatar
oh new unused. haha ok, i'll do the experiment, i can swap out the caps. So your saying within 15 minutes there should be an audible difference? And this only happens once with FC's? also have you heard other caps that took longer?
never mind the last part i just reread your post about the gates
Old 6th June 2007, 08:55 PM   #9
"And this only happens once with FC's? also have you heard other caps that took longer?"
actually other panasonic electrolytics in signal path also behave the same in my experience. This might not only happens once, the longer the equipment is not used, the "break-in" need to be redone, hence my dislike for blackgates.
Hartono
Old 6th June 2007, 09:05 PM   #10
impsick's Avatar
cool. thanks for the very simple and informative replys.
re-conditioning PA cabinets levyte357 PA Systems 17 24th November 2008 04:29 PM
Power Conditioning whitelabrat Power Supplies 9 29th January 2008 01:42 AM
power conditioning lopan Power Supplies 5 27th November 2004 08:29 PM
power conditioning andrewe1 Tubes / Valves 39 14th September 2004 11:43 PM
Page generated in 0.10104 seconds (76.63% PHP - 23.37% MySQL) with 10 queries
