6-channel amp
6-channel amp
Old 25th January 2003, 09:00 AM   #1
2Bak is offline 2Bak  Denmark
Default 6-channel amp
I need advise.
For a small room I need a cinema power amp, about 30-50 watt
per channel (in one case) to drive:
- Surround L og R
- Center
- Sub L og R
Front L og R are driven by my normal 2-channel power amp. Pre-amp is multichannel with built-in processor.
The way I see it, it will be six channels. Three
stereo amps where one of them is bridged to be used for the center speaker...
How do I proceed? I was thinking of a simple (and not too expensive) class A/B amplifier.
With three power supplies, one for each stereo amp. This will also make it easier for me to build I guess, cause I'm not too stiff in electronics.
Anyone can recommend simple two-channels A/B
power amp circuits to be build in one case, about 45 *
35 * 13 cm?
The reason for having L and R channels for sub amp is that I plan to have small passive subwoofers in both L and R channels (I am building L & R front loudspeakers which will have room for a woofer in the bottom).
The existing L and R power amp is Audio 60 (Doxa) class AB 2*60 watts.
6-channel ampHide this!Advertise here!
Creating 5.1 Multi Channel sound from 2 channel jenkrich Everything Else 5 1st September 2009 07:29 AM
4 channel conversion to mono 1 channel iUSERTLO72p Car Audio 24 25th October 2007 05:07 PM
HELP!: Channel volume very very low, other channel fine. harrisni Solid State 2 20th September 2006 11:10 AM
My 4 channel car Amp distorting on 1 channel (large pics) MikeHunt79 Car Audio 9 3rd September 2003 06:41 AM
Help quick! 4 Channel > 2 Channel? zmoz Car Audio 3 5th July 2003 08:48 PM
