I just got a used NAD reciever on e-bay that the guy said "everthing works fine and is in excellent condition"
Without anything attached I plugged it in to check it's power up and it made a "Clunk" where the power cord enters the back of the unit. I can unplug it and it does that silently, but everytime I plug it in it goes CLUNK A green light comes on in the corner of the led screen but that's all that works. Does anyone have an idea what the problem might be? |
#2 |
Got a screw driver?
Over compression is a problem with modern CD recordings |
#3 |
Yea, I just got one one in the mail
#4 |
All may not be lost ... open 'er up and see what is "clunking" around in there, then maybe you can fix it with a little solder / glue / bubble gum ...
#5 |
I checked the fuses with a volt meter and they all test out ok. The clunk noise comes from underneath what looks like a mini transformer ahead of the larger one right where the power cord comes in.
I read something about relays can cause that kind of sound but thats out of my expertise level. |
#6 |
It probably has a mini transformer to supply a standby voltage to a microcontroller. THe main power is then switched on by the micro when you press the power button. I guess for some reason, that's not working right.
To be honest, if you don't have any electronics experience, it's best to leave repair to a professional. Make sure you give that sucker bad feedback! |
#7 |
thanks guys, no I don't feel that electrically inclined.
He gets Pay-Pal arbitration and REALLY bad feedback if he doesn't respond positively soon |
#8 |
" ... The clunk noise comes from underneath what looks like a mini transformer ahead of the larger one right where the power cord comes in. ..."
Please look around for loose screws and floating small parts before you close it up ... I always turn my projects upside down and shake 'em before closing the hood ... those tiny little bits of solder can really mess up your day ... zzzzzttttttt " ... The main power is then switched on by the micro [relay?] when you press the power button. ..." If your clunking noise is a "slow start" relay, then not to worry ... it will either eventually fail, so you can then replace it ... " ... He gets Pay-Pal arbitration and REALLY bad feedback if he doesn't respond positively soon ..." I would not condemn the device just yet ... or give someone some bad feedback until you are sure that there really is something wrong with the device. The important thing is: How does the amp sound ???
#9 | |
Well, this was his response:
#10 | |
After reading that I tested some more and unfortunately had to reply:
| Dead AKG P 8E with X 8S R | Bernhard | Analogue Source | 10 | 2nd April 2008 11:55 AM |
| dead amp | ddoyle | Chip Amps | 20 | 30th July 2007 02:30 AM |
| Nak mb-70 dead ? | MadMutt | Car Audio | 10 | 5th April 2007 04:18 AM |
| is my amp dead? :( | torxim | Car Audio | 5 | 18th September 2004 11:37 AM |
| Page generated in 0.11728 seconds (77.90% PHP - 22.10% MySQL) with 10 queries |
