I sprayed deoxit into a little hole on the front of the NAD 3020 volume pot (knob removed) to fix a tracking problem. Now if I turn it up past about 11:00 the right side kicks in at full volume, like it's not attenuating at all anymore. oop! it's fine at this volume for a bit and I think I'll grab an alps control off ebay or go to rat shack, I just want to learn from my mistakes. What did I break?
thanks!
GhettoSQ Somewhere between Craft and Kraft |
#2 |
frugal-phile(tm)
2 of the most common failures in 3020s is the power switch & the volume control. I'd suggest replacing it.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#3 |
Yeah, I knew i'd have to at some point. is this one any good?
http://cgi.ebay.com/ws/eBayISAPI.dll...1099&rd=1&rd=1
#4 |
frugal-phile(tm)
That should work just fine...
dave
#5 |
Thanks...sometimes i worry about cheap knockoffs, but it seems perfect.
#6 | |
frugal-phile(tm)
dave
#7 |
LOL touche
thanks again.
#8 |
I got that control, installed it easy, it fits and works fine. Only trick is there's no provision for the loudness control, which I never used, and it's a 50Kohm whereas the original was 500Kohm. I just use the muting switch.
thx for the help!
#9 | |
frugal-phile(tm)
dave
#10 |
Hmmm...the old one was oriented funny, meaning the little tab that goes into the hole to hold it in place was on the other side so the control was upside down. Maybe it was replaced once before (I got it used). Still, the new one needs to be almost all the way down without the mute, for it to be listening volume. Go to 9:00 and your windows are blown out.
| Volume control on DVD player remote. Lose resolution at low volume? | Circlotron | Digital Source | 2 | 10th June 2011 07:20 PM |
| i need preamp schematics w/o tone control or volume control | hernanstafe | Parts | 7 | 30th January 2008 03:12 AM |
| The remote control paratactic volume control | audio-gd | Solid State | 33 | 7th June 2007 11:16 PM |
| PC volume control | sumacSK | Chip Amps | 9 | 28th November 2005 05:33 AM |
| remote control motorised control for volume pot/knob | CharlesY | Parts | 0 | 25th July 2005 11:12 AM |
| Page generated in 0.11016 seconds (78.34% PHP - 21.66% MySQL) with 11 queries |
