Old 4th June 2007, 01:51 AM   #1
Gold_xyz's Avatar
Default QSC style single supply
I want to rebuild my old 100W amplifier with BDX66C/67C
which advantages do I have if I use a scheme as the famous amplifiers QSC?
Filter capacity is 4700/2 = 2350uF
My English originates from here
Old 4th June 2007, 06:37 AM   #2
Jan Dupont's Avatar
Send a message via MSN to Jan Dupont
Famous in what way ?
Only advantage is that you only need a single rail power supply.
On the other hand, you get two large caps in the signal path
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com
Old 4th June 2007, 12:08 PM   #3
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
The capacitors are *always* in the "signal" path, no matter if the transformer has a center tap. However, they may be inside or outside the global feedback loop.
In that particular schematic the capacitors will be always inside the feedback loop, no matter if ground reference is taken from capacitor mid point and feedback from the emitters or vice-versa. Some means of DC balancing is required, though.
I use to feel like the small child in The Emperor's New Clothes tale
Old 4th June 2007, 02:15 PM   #4
Gold_xyz's Avatar
Famous at least for the schematics...
(My face at the first look of these schematics : )
This configuration can resolve the start amp bump.
-experiments coming soon -
Yes, for my amplifier I need to added a small capacitor for feedback
line. Resistor of feedback R15 is 5.6K
Schematics:
From Italian PHILIPS ELCOMA (1981)
Old 4th June 2007, 02:38 PM   #5
Did it Himself
richie00boy's Avatar
I would add balancing resistors across each cap. Other than that, interesting!
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 4th June 2007, 03:05 PM   #6
jaycee is offline jaycee  United Kingdom
Surely this is bad news if one of those caps fails ?
Old 4th June 2007, 03:20 PM   #7
Did it Himself
How is it any worse than if a cap fails in a 'normal' PSU?
Old 4th June 2007, 03:23 PM   #8
Gold_xyz's Avatar
This solution in my amplifier not eliminate the bump at start.
(when the capacitor are discharged)
Old 4th June 2007, 03:34 PM   #9
Did it Himself
There is probably nothing you can do. You should post your schematic of amplifier
Old 4th June 2007, 03:42 PM   #10
Gold_xyz's Avatar
schematics can be found here :
and here:
http://ck703.altervista.org/subdir01/philipselcoma.html
I try to rebuild my old amplifier100W with bootstrap and single supply.
printer single supply becoming split supply? facundonu Power Supplies 2 16th November 2006 06:09 PM
OPA549 on single supply bostjancek Chip Amps 8 12th September 2005 02:05 PM
Choke for preamp to get battery style power supply? Sigurd Ruschkow Power Supplies 1 18th March 2005 07:55 AM
single supply for lm3886 xplod1236 Chip Amps 5 5th April 2004 01:03 AM
Single supply sub filter palesha Solid State 15 4th September 2002 03:28 PM
Page generated in 0.10859 seconds (75.69% PHP - 24.31% MySQL) with 11 queries
