Hiss in my P3a Amp - Page 2 - diyAudio
Old 30th May 2007, 01:12 AM   #11
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
Limit the input bandwidth to something like 160kHz.
Old 30th May 2007, 01:18 AM   #12
anatech is offline anatech  Canada
anatech's Avatar
One would think that 40~80 KHz might be a better target. 6 dB / oct, passive R-C low pass filter.
-Chris
"Just because you can, doesn't mean you should" my Wife
Old 30th May 2007, 03:06 AM   #13
The P3A does already have an ultrasonic filter formed with the 220pF capacitor on the input. It's -3dB down at about 360KHz.
I'd check the components on the input. The 220pF should ideally be a polypropylene and not a ceramic, although a monores ceramic might be ok here.
To try the steeper filter idea out, change it to 470pF for a cutoff at about 170KHz.
Old 30th May 2007, 02:14 PM   #14
anatech's Avatar
Hi jaycee,
I'm thinking that the garbage coming out of the computer sound card may come in at 96 KHz, possibly lower. This is not a good situation. 44.1 KHz stuff would be much more difficult to get rid of. It may also be beating against power supply noise. $20 power supply, I wouldn't be surprised if this were to occur.
-Chris
Old 31st May 2007, 10:43 PM   #15
Default FIXED
Found the problem. One of my 570ohm resistors was disconnected. Problem fixed.
Now I gotta fix my other channel. Blew one of my speakers when testing it. I think i have a bad C3 cap. Waiting for parts.
Old 1st June 2007, 01:52 AM   #16
anatech's Avatar
Hi blap0220,
Good show!
-Chris
Hiss but no hum... RockysDad Tubes / Valves 13 5th April 2009 05:35 PM
SI T-amp - bad hiss in one channel toolkit Class D 7 30th November 2006 12:47 AM
Autocostruire t-amp hiss ? mirland Class D 29 29th September 2005 07:18 PM
Fullrange hiss ? mirland Full Range 14 28th September 2005 11:43 AM
hiss jaudio Chip Amps 21 6th March 2005 05:02 PM
Copyright 1999-2017 diyAudio
