Old 28th May 2007, 10:03 PM   #1
Juko is offline Juko  Netherlands
Default Cyrus 3i
Hi all,
I'm about to buy a Cyrus IIIi which gives a pop over the speakers when you turn it on. What kind of problem could this be?
And is it not to much trouble to repair it?
Old 30th May 2007, 08:40 PM   #2
I got the amp
Some more diagnostics:
when in standby I measure up to 7V DC on both outputs.
When turned on output DC goes down to zero.
When in standby again it develops the DC again.
Shouldn't be to hard to repair I think, but what could be the problem?
Any Cyrus experts?
Does someone have a schematic for me?
thanks in advance
Old 31st May 2007, 06:43 AM   #3
jaycee is offline jaycee  United Kingdom
There is probably a relay to disconnect the speakers, and either the relay or the circuit controlling it has stopped working. That's entirely a guess, to be honest!
Old 31st May 2007, 08:05 PM   #4
there are no speaker relays, so i don't think that's the problem
Old 31st May 2007, 10:28 PM   #5
anatech is offline anatech  Canada
anatech's Avatar
Hi Jurriaan,
There is a problem all right. These do not have a relay to disconnect the speakers and normally do not pop. A 7 VDC offset needs to be repaired, don't continue use until it's fixed.
This is not a job I'd recommend that you attempt. There are 24 smt parts that need to be replaced as a proper fix. These are all transistors. You should send it to the factory for this. I do them in Canada. England isn't that far away from you and the guys at the factory do good work.
I used to troubleshoot the leaky transistor, but that is largely a complete waste of time. It is far more prudent to replace all of those things. If you attempt this yourself you must be extremely careful. Some of these parts are hard to get to, and the pads may be lifted if you are not experienced. I hate getting one of these in that have been "struck by technician".
Now for the good news. If done properly by a good Cyrus technician the fault will not reoccur.
-Chris
"Just because you can, doesn't mean you should" © my Wife
Old 1st June 2007, 05:24 AM   #6
Hi Chris,
Thanks for the advice. I send an email to Cyrus. I hope it can be repaired in the Netherlands.
Jurriaan
Old 1st June 2007, 02:18 PM   #7
anatech's Avatar
Hi Jurriaan,
I understand your desire to have it done locally. The most important thing is the skill of the technician. That will have a great bearing on future performance.
I know a good technician there. I'll send him an email to see if he wants to do this ugly job. Understand that seeing one come through the door with this fault does not make me happy. I do them to the best of my ability and it's work.
-Chris
Edit: Request has been sent.
Old 1st June 2007, 04:53 PM   #8
Chris,
Many thanks, he already contacted me.
Edit:
I see it's in Belgium, well that's a pretty long drive for me, but we will see .
Old 1st June 2007, 05:03 PM   #9
anatech's Avatar
Hi Jurriaan,
I think it's worth the drive. These are very easy to ship via post too. Hugo knows how to deal with this amplifier, so either go to him or use the factory - please.
-Chris
Old 1st June 2007, 08:26 PM   #10
I take your advice very seriously. But I don't have that much money (I'm a student), so I have to consider things wisely.
I hear from your words you love cyrus amps and wish them the best and Hugo sounds to me like a nice fellow. So don't be afraid that I let someone mess up my amp .
cyrus 2 atomised Solid State 350 19th December 2011 11:42 AM
WTB Cyrus 1 or Cyrus 2 amplifier monstertrucker Swap Meet 0 20th November 2008 02:04 AM
Trying to fix my Cyrus II amp karl.s. Solid State 9 18th September 2005 03:07 PM
Want: Cyrus Lid richie00boy Swap Meet 0 27th April 2005 01:39 PM
cyrus 7 and 8 honsten Solid State 2 15th February 2005 11:26 PM
Page generated in 0.09629 seconds (77.87% PHP - 22.13% MySQL) with 10 queries
