I hope this is a simple question. If I want an amplifier to operate push pull in class A to produce power level "x" what standing bias level sould the output devices be set to? i.e. y(x). or another way to express what I want to know, if I need to deliver 100mA to the load, should I set the standing bias at 400mA or what for low distortion full class A operation.
#2 |
I'm probably wrong, but with push pull you set the idle current to half your wanted peak current
#3 |
Hi Tubesman
see http://www.borbelyaudio.com/adobe/classa.pdf you will find all you need to perform your calculation of bias current for class A in push-pull Good luck |
#4 |
thanks for the link I will read it now
#5 |
If you are after the bias that gives minimum distortion then biasing it slightly above the current needed. If you hook up an IV analyzer to a bjt you will see that as the input voltage nears cuttoff there is a nonlinear bend in the transistor's current curve. Biasing above this point so that the transistor doesnt reach this bend in the curve will keep the transistor in it most linear area and give minimum distortion.
#6 | |
The one and only
#7 |
basicly start with the calculated current and go up from there with a THD meter.
#8 | |
from the matematik point of view but as jerluwoo says: we should add like +10 to 20% to this figure, for good output at wanted Max sometimes, whether Push-Pull or Single End, I have added as much as 30% ... it depends on what amplifier circuit I use, from case to case different
lineup |
| What makes an amplifier "bright", "warm", or "neutral"? | JohnS | Solid State | 51 | 13th December 2009 06:42 PM |
| alphasonik class "d" 2400 watt amp... frizznied | ppia600 | Car Audio | 18 | 9th April 2009 03:55 AM |
| Schematic for Zetex "ZXCD500MOEVAL" - Class D Eval Board ? | CAindoAUDIO | Class D | 1 | 16th November 2006 03:44 PM |
| "cable chargers" - DC biasing cables? | dorkus | Everything Else | 20 | 21st June 2002 07:41 PM |
| Page generated in 0.09443 seconds (77.04% PHP - 22.96% MySQL) with 10 queries |
