Pathos Amplifiers
Pathos Amplifiers
Old 23rd January 2003, 01:41 PM   #1
RichardJones is offline RichardJones
Default Pathos Amplifiers
Having built some SE Class A amps... I am interested in the Pathos output stages....
Does anyone have a partial schematic or knows how it is wired?
Thanks!!!
Old 23rd January 2003, 02:36 PM   #2
Joe Berry is offline Joe Berry  United States
As I understand it, Pathos makes two types of output stages. For
class AB working, they use complementary MOSFETs in push-pull.
For single ended (or balanced SE) class A, they use their "INPOL"
circuit, described on their web site at www.pathosacoustics.com.
From descriptions I've read, I gather that INPOL is basically a
source follower loaded by a choke and coupled to the load by a
capacitor. The choke and cap together form an energy storage
system that supplies most of the dynamic output current, while
the source follower MOSFET controls the output voltage.
The key claim for this approach is that it allows the follower to
work under nearly constant-current conditions, so it can control
the output voltage with great accuracy.
Old 23rd January 2003, 05:42 PM   #3
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
Pathos Amplifiers
A follower loaded by a choke will see the full AC current
through the load. There is no mechanism in that arrangement
for constant current through the device.
Old 23rd January 2003, 06:50 PM   #4
scottnixon is offline scottnixon
Wink Inpol this!
Kinda sorta what's goin' on
Old 23rd January 2003, 07:11 PM   #5
Then perhaps I have misconstrued the claims made on their web
site. Unfortunately I can't locate a copy of their patent, from which
one might better understand and assess these claims.
In any case, the schematic posted by scottnixon above seems to
agree with the basic description given by Pathos and others.
Old 23rd January 2003, 07:22 PM   #6
Default modification....
Couldn't we choke load the 12AX7 cathode follower.... then use this to direct couple to the mosfets gates?
output operating current then dependent on the voltage drop across this choke.
Instead of a 12AX7... use a 6BX7 or something like that.
This would get rid of a coupling cap at least...
thoughts?
Old 23rd January 2003, 10:42 PM   #7
Default I knew I wasn't making this up
Doing some more digging on this, I unearthed a review of the
Pathos Twin Towers amp by Dan Sweeny in Issue 116 (Feb '99)
of The Absolute Sound. In a sidebar on INPOL theory, he explains:
"Under no-signal conditions, the choke allows direct current to
flow unimpeded from the positive supply to ground [while] the
parallel capacitor ... provides additional energy storage while
equalizing the current draw for either half of the wave cycle, i.e.,
when the [output] MOSFET is sourcing or sinking current ...
"Impedances are set so that the total series impedance of the
capacitor plus the loudspeaker circuit is somewhat higher than
the impedance to ground; therefore current through the output
transistor never varies appreciably even though the internal
impedance of the MOSFET drops with increasing signal voltage."
In an effort to see if this could possibly be true, I quickly modeled
the INPOL output stage in Electronic Workbench. In this model at
least, the current through the MOSFET does vary by about 2:1 at
full output, just as it would with a constant current source load.
This appears to negate the claim of constant current operation.
This kind of choke loading does offer the benefit of cutting the
idle dissipation of the output stage in half when compared to a
CCS loading, as there is no need for a corresponding negative
power supply rail.
Old 24th January 2003, 12:04 AM   #8
Pan is offline Pan  Sweden
Even though I donīt understand half of this circuit to me it looks like the caps are there for no reason.
Circlotrons choke amp has no cap at output and only a tiny amount of offset.
/Peter
Old 24th January 2003, 04:55 PM   #9
The one and only
Pathos Amplifiers
That statement makes no sense to me at all, particularly
in reference to the Pathos schematic.
Old 24th January 2003, 05:10 PM   #10
tvi is offline tvi  Australia
tvi's Avatar
The Closest Patent I have seen to the Inpol output stage
is US Pat 5498997 to Cristopher Schiebold, March, 12, 96
See pic
Regards James
Pathos AmplifiersHide this!Advertise here!
Pathos Classic one priax Tubes / Valves 5 12th July 2013 02:32 PM
pro amplifiers vs. home audio amplifiers bonsai171 Solid State 26 25th February 2004 08:24 PM
5.1 amplifiers bryce Digital Source 0 13th February 2004 04:17 PM
Paradigm amplifiers? Anthem amplifiers? Corn-Picker Solid State 2 24th January 2004 03:10 AM
Many smaller amplifiers vs. bigger amplifiers. djdan Solid State 9 17th September 2002 04:40 PM
Copyright ©1999-2017 diyAudio
