Need Help - Burnt Sanken
Old 26th May 2007, 10:20 PM   #1
p.heimpold is offline p.heimpold  France
Default Need Help - Burnt Sanken
Hello,
after modding my Musical Fidelity X-T100 I connected it for 2 minutes without heatsinking the SAP15N and P transistors (Darlington output stage as described in the Sanken datasheet)
and they burnt.
At least, that is what I think: they were very hot after the "smokey" event and the 4A fuses blew.
I modded the amp especially in the preamp stage that seems to work fine.
The only items that I changed in the power stage are the rectifier bridge (rebuilt with 8A stealth diodes K-K DC+ / A-A DC-) and two capacitors.
When I replace the fuses and turn of the amp, the amp lights on and the fuses do NOT blow, but there is no sound at the speakers.
Any idea and suggestion on how to proceed in trouble shooting? I think that I have to replace the transistors (need to check whether B-C-E are shorted), but if they were shorted the fuses would have to blow, no?
Any help and advise is greatly appreicated.
Patrick
Old 26th May 2007, 10:52 PM   #2
Nordic is offline Nordic  South Africa
Nordic's Avatar
confirm speakers still work first.
Old 27th May 2007, 12:41 AM   #3
jaycee is offline jaycee  United Kingdom
Without heatsinking, all bets are off. You have toasted the outputs, and if youre unlucky, more of the circuit.
If you had speakers connected, check them, because if you were unlucky, they are toast too.
Old 27th May 2007, 11:45 AM   #4
Hello and thanks,
I am assuming the outputs are dead.
I re-checked the fuses and they blow, connecting another speaker to the amp does not produce any sound.
For what concerns my main speakers, they should be OK as I have an impedance mathcing transformer between them and the amp but yes, that one might be cooked.
What I wonder: can it really take so little time for a pair of transistors to heat up so much?
Patrick
Old 27th May 2007, 12:07 PM   #5
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Originally posted by p.heimpold
I connected it for 2 minutes without heatsinking,they were very hot after the "smokey" event.
Eeeh,
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 27th May 2007, 12:36 PM   #6
I know, I could hammer myself for that but my intent was just to see whether I had hooked up everything correctly...
Old 27th May 2007, 01:24 PM   #7
jackinnj is offline jackinnj  United States
jackinnj's Avatar
the SAP16N, SAP16P are now unobtainium -- here's the Sanken replacement from Profusion:
http://www.profusionplc.com/pro/gex/...r%20darlington
I thought that these transistors had built in over-temp compensation -- there is a diode string in the P and N devices which change the bias current with temperature -- at least that's how they are supposed to work. I think that there might be other things going on.
FWIW, I haven't used the replacement devices yet.
Old 27th May 2007, 02:00 PM   #8
Hello Jackinnj,
my understanding is that the current sensing is meant to regulate "the temperature dependency of the idling current".
I understand your concern that something else might be going on.
I also would like to ensure this.
For what concerns the Power Supply of the output stage, I only rebuilt the rectifier bridge with 4 diodes. C-C to DC+, A-A to DC-.
Any suggestion on how to measure it is working fine?
I unsoldered the two PNP transistors and it becomes apparent that:
1) one has a nice crack
2) one has a "vulcan", looks like a burnt part inside the transistor
I measured resistance across B / C / E and they look OK (value pops up shortly and then gets back to zero) except for C-E on transistor 2), there seems to be a permanent short.
Measuring tension between the legs shows that BE on transistor 2) is about 970mV whereas the others are around 890mV.
My guess: P Transistors are damaged.
Will check the N Transistors now.
Bets regards
Patrick
Old 27th May 2007, 02:27 PM   #9
N Transistors also show inconsistent values amongst them, so my best guess is to change the two pairs.
Patrick
Old 28th May 2007, 12:29 AM   #10
destroyer X is offline destroyer X  Brazil
destroyer X's Avatar
Default I feel extremelly sorry as you have lost them
C'est la vie mon ami
Better luck next time.
Probable that output have melt and maybe drivers too.
regards,
Carlos
Dx unbeatable amplifiers; https://www.youtube.com/watch?v=u4tGBiqMnzQ
Need Help - Burnt SankenHide this!Advertise here!
Help! tube amp burnt? flatsound Tubes / Valves 9 26th June 2009 03:41 AM
IRFP064 gets burnt xyz9915 Power Supplies 30 5th February 2009 03:57 AM
xtant A2002 amp burnt? hbch Car Audio 1 12th November 2008 11:52 PM
Sub burnt bad. Garbage? Miedosoracing Subwoofers 4 27th April 2006 02:59 PM
burnt transformer A'af Digital Source 1 21st May 2005 12:23 AM
