I have been reading threads on the different types of wire and have noticed that PVC wire is not a very good choice. I am assuming that the PVC does not make as good of an insuator as the others (telfon, PP, etc.). Has any one tried internally wiring their amp with PVC wire and then changing it to a higher quality wire? What effect did it have on the sound?
Also, many DIYer's here use very nice braided wire for the small signal. I was wondering if the signals and the grounds are all braided together? |
#2 |
RobPhill,
have a look at this info on DIY cables - you may find it helpful. John Risch moderates the cable forum at audio asylum and can be contacted there if you have any questions left after digesting all his material. http://www.geocities.com/jonrisch/cables.htm Regards 13th Duke of Wymbourne |
#3 |
Teflon wire has a higher melting temperature. If you are wiring it near hot components such as heatsinks and transformers you are better off using something that will not melt as easily as PVC. Also, the current capacity of a wire is defined by the amount of current that can be passed through the conductor at a certain ambient temperature before A) the conductor melts or B) the insulation melts. Many teflon coated wires are silver tinned copper which is good for corrosion protection and good conductivity.
BeanZ |
#4 |
Making general assumptions about insulation and perceived sound quality is dangerous. While it seems generally accepted that PVC sounds bad and teflon great there are lots of exceptions. Unless you're dealing with a known brand of wire it's quite difficult to predict the sound. I have lots of teflon insulated silver multistrand hook-up wire which sounds so bright that can make your ears bleed.
cheers peter |
#5 | |
Can you name those bright sounding teflon multistrands? Carlos |
| Winding coil with Teflon insulated wire ? | Bernhard | Parts | 1 | 1st June 2008 10:25 AM |
| teflon wire stripper | sam9 | Parts | 15 | 12th February 2005 09:42 AM |
| Teflon insulated magnet wire? | serengetiplains | Parts | 52 | 17th June 2004 09:55 PM |
| teflon 23ga. hookup/signal wire?... | Guiness | Tubes / Valves | 21 | 28th April 2003 03:39 PM |
| Teflon wire and Tantalum resistors... | AudioFreak | Parts | 7 | 31st January 2002 02:08 PM |
| Page generated in 0.08555 seconds (71.90% PHP - 28.10% MySQL) with 10 queries |
