diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Solid State (http://www.diyaudio.com/forums/solid-state/)
-   -   upgraded my pioneer sx-3700 (http://www.diyaudio.com/forums/solid-state/102440-upgraded-my-pioneer-sx-3700-a.html)
audiobahnkid592 24th May 2007 04:01 PM
Not sure if its in the right spot but I had a Pioneer SX-3700 laying around it was supposed to be 45W by 4 RMS. I put in amp chips from a car amp and now it delivers 200 RMS by 2. While I was in there I put a fan blowing on the heat sink. While I was Pushing it to the max with NO distortion the heat sink became 150F as soon as I turned the fan on it became 89F within one minute. I am very pleased with this and my question is: is 150F to hot for a heatsink?
richie00boy 24th May 2007 04:08 PM
Re: upgraded my pioneer sx-3700
I very much doubt that, unless you substantially upgraded the power supply as well.
jaycee 24th May 2007 04:55 PM
"amp chips" from a car amp? Presumably you mean you changed the output transistors. This in itself, will do absolutely nothing to increase power output - however, it may well have made the circuit oscillate, thus explaining the heatsink getting so hot.
audiobahnkid592 24th May 2007 11:08 PM
it does push out more power put volt meter on while playing the subwoofer before had about 13V AC after it was all done there was significantly less distortion and about 24V AC across the speaker terminals while playing subwoofer. Also it has a "watt Meter" on the front it goes up to 80W at 8 ohms it say and its well over that at very low volume.
Copyright 1999-2017 diyAudio
