Class A/B folded cascode amp
Old 27th May 2007, 06:56 PM   #11
Khron is offline Khron  Finland
Send a message via AIM to Khron Send a message via MSN to Khron Send a message via Yahoo to Khron
This is a bit off-topic here...
I'm from Romania too, a few hundred km's north of you
I had sent you an email inquiring about the latest version of your evolution of Mr. Bittner's Symasym (schematic, maybe pcb, and in an ideal case, some extra documentation/measurements).
Thanks in advance
Cristi
Old 28th May 2007, 01:37 PM   #12
roender is offline roender  Romania
roender's Avatar
Thanks in advance
Cristi
I've send you an e-mail with all the necessary details for implementing "symasym roender style"
Regarding symasym, whatever variant may be, it will measure much better than folded cascoded amp presented here but it will sound a little bit "worse"
Keep in mind, however, that this is a subjective opinion.
I suggest you to test each variants and choose what you like more
Old 16th July 2007, 02:26 PM   #13
atiq19 is offline atiq19  United Kingdom
Default class a/b folded cascode amp construction
Roender,
Can I have construction details for your amp?
I'll need pcb layout and building instructions for your amp.
How does it sound if I was to listen vocal based songs?
Many thanks.
Atiq
Atiq19
Old 17th July 2007, 12:12 PM   #14
Roender,
I don't know why you can't reply me to:
atiq192003@yahoo.co.uk
Atiq
Atiq19
Old 17th July 2007, 02:10 PM   #15
roender's Avatar
I can't recommend you to build this one because I don't have a finished PCB. Also, there is a small problem with front stages PSU.
I'll update the thread when all this problems are solved.
Old 17th July 2007, 02:41 PM   #16
Symon is offline Symon  United Kingdom
Just for reference MikeB also worked on a folded cascode design.
http://www.diyaudio.com/forums/showt...388&highlight=
Old 17th July 2007, 02:52 PM   #17
roender's Avatar
Indeed, very similar design, but only as topology
Old 17th July 2007, 03:08 PM   #18
Default class a/b folded cascode amp update
Roender,
Thanks for your reply. I thought you already tested and finished that amp! What happened to the PSU in front end? I suspect it's minor. How do you compare this version with Mike's Symasym?
Cheers!
Atiq
Atiq19
Class A/B folded cascode ampHide this!Advertise here!
Folded cascode headphone amp nelsonvandal Headphone Systems 266 28th March 2009 08:12 PM
folded cascode the_tool Chip Amps 1 27th June 2006 10:53 PM
Symmetrical folded cascode. Mr Evil Solid State 195 1st April 2005 04:15 AM
folded cascode puzzling drakonis Pass Labs 6 30th March 2002 10:04 PM
Folded cascode question Won Solid State 3 11th January 2002 08:10 PM
Copyright ©1999-2017 diyAudio
