Old 22nd May 2007, 08:31 AM   #1
etsang3 is offline etsang3  Hong Kong
Default Meridian Tuner 204
I have just repaired a faulty Meridian 204 Tuner (cannot be turned ON) and would like to share some photos.
Front Panel Module
http://i20.photobucket.com/albums/b2...playmodule.jpg
Change to IC socket for easy maintenance
http://i20.photobucket.com/albums/b2...dICsockets.jpg
The Logical Control Board
http://i20.photobucket.com/albums/b2...r/MPUBoard.jpg
SAA3006(RC-5) output when Button #2 is pressed
http://i20.photobucket.com/albums/b2...er/Button2.jpg
Add filter cap for lower hum noise figure
http://i20.photobucket.com/albums/b2...dfiltercap.jpg
SAA3006 and the control keys
http://i20.photobucket.com/albums/b2...6Incircuit.jpg
SAA1061 for LED display
http://i20.photobucket.com/albums/b2...061display.jpg
Display Module connection to front panel
http://i20.photobucket.com/albums/b2...nelconnect.jpg
Old 13th March 2009, 04:33 AM   #2
smitsch is offline smitsch  Switzerland
Hi There
i've got same issue here - did u replaced only the both SAA's ? or is the display module also affected ? (i have a newer design on PCB, do not need to unsolder it for IC change)
- what should i check before i plug the Mains?
thanks for any help, Mitsch
Old 10th December 2009, 06:12 AM   #3
hew128 is offline hew128  Singapore
I recently replaced the battery on my 204 and initially it acts as if it was dead. Then after the battery charges up, works fine when coupled to my 201.
Old 10th December 2009, 11:10 PM   #4
Yep,
my Meridian 204 tuner is also working again, but it was more then just the Battery to replace...it was:
key driver chip, display driver chip and even CPU!
i have a scheme as pdf if anyone needs it...
CPU: if there is something like in between Hi and Lo (+/-3V) on Busses, it has to be replaced...
a fine tuner who is worth to be repaired...i like it, but if anybody wants it, i cold even sell it...
stay FM!
Old 11th December 2009, 12:05 AM   #5
Please sent the PDF to hew128@hotmail.com
Don't suppose you have the RC5 codes for the 209 as well?
Many thanks!
Old 11th December 2009, 09:37 PM   #6
i will do, but for now until January 4th i´m travelling...be patient...
Old 24th February 2010, 01:43 AM   #7
Default scheme!
this is what may help! good luck! sorry, no rc- codes...
Old 24th February 2010, 09:49 AM   #8
Hi Smitsch, Thank you very much indeed. Have a nice day.
Old 5th March 2011, 04:08 PM   #9
dray177 is offline dray177  France
Originally Posted by smitsch View Post
Yep,
I have a scheme as pdf if anyone needs it...
Many Thanks SMITSCH for your contribution ( your schemes ).
My Meridian is out of order :
- display panel with erratic functions
- battery NiMh < 0,5 volt
I will do changing to solve ( hope it the reason of troubles ).
Raymond
My Meridian 565 mod PWatts Digital Source 1 5th January 2012 07:55 AM
Meridian MCD barry.childs Solid State 9 14th March 2010 03:10 PM
Larsholt fm tuner front end for JLH tuner design-Any still available? djsb Analogue Source 0 25th December 2008 04:46 PM
Meridian 508-20 Richard984 Digital Source 14 2nd February 2008 09:49 AM
Meridian 104 Tuner richardsymes Analogue Source 2 13th June 2007 07:37 PM
Page generated in 0.10086 seconds (80.48% PHP - 19.52% MySQL) with 11 queries
