Build a BTL design or a multichannel set???
#2 |
150 volt/amps ... assuming center tap, +/- 30 VAC, perfect for a single channel 150 watt amp ...
Over compression is a problem with modern CD recordings |
#3 | |
+/- 30 volts would be 60 x 50 = 300VA. ![]() PS: If you don't need it, I'll take it
#4 | |
You miss one zero, 60 X 50 = 3000 VA
#5 |
30V * 50A = 3000W
I use to feel like the small child in The Emperor's New Clothes tale
#6 |
Yes.Two 30-0V with 50A each.Weight more than 20kgs each and they are EI transformers.
1500VA x 2,but have no idea to use them properly.
#7 | |
Ooops! My boo-boo. |
#8 | |
Too big for your needs? Just because they can supply 50A, doesn't mean you have to have something that can draw that much. For an amp, you are limited by the speakers impedance and the voltage. Would be great for a 6-8 channel amp, though. Or, sell it on Ebay.
#9 |
Too bad ... 0 to 30 VAC with no center taps and 3k watts ... probably used for an old computer server or such. Not much good for audio unless, as suggested, you want to do multiple amps in one chassis. ... like four or five channels of 100 watts / each MOSFET amp = a difficult design as quality goes down with lower supply voltages and 0-30 VAC will also require a significant split gound simulation to get +21 /0/- 21 VDC ... (Sorry about that multiply error = a senior moment?)
#10 |
If my (hopefully conservative) calculations are right:
Take two 0-30V transformers and wire them in series so that you get one 30-0-30. VA = 2 x (50x30)= 3000VA (I think VA works that way). Unless you are going to get into voltage doublers, this will let you power a number of ~80W (nominal 8 ohm load) amplifiers. Easily 7 channels of amplification with current to spare. If you wanted to try a voltage doubler (big diodes suggested) you could power 5 channels at 350 Watts with just enough left over to handle 4 ohm speakers. Add some big heat sinks and get a big friend, or hand truck to move these around. |
| Using mains transformer as output transformer | Elias | Tubes / Valves | 175 | 3rd November 2009 08:36 PM |
| Modulation transformer for a driver transformer? | ironradio | Tubes / Valves | 6 | 28th December 2008 05:05 PM |
| filament transformer vs plate transformer | contaxchen | Tubes / Valves | 10 | 14th January 2005 10:43 AM |
| toroid Transformer as power Transformer for tube | tone | Tubes / Valves | 7 | 11th February 2003 08:57 AM |
| toroid Transformer as output Transformer for tube preamp? | tone | Tubes / Valves | 15 | 2nd February 2003 04:36 AM |
| Page generated in 0.09903 seconds (79.00% PHP - 21.00% MySQL) with 10 queries |
