How many maximum Vcc for TIP2955 & TIP3055?
Old 21st May 2007, 01:26 AM   #11
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
+/-35V is fine for TIP2955/TIP3055.
Old 21st May 2007, 02:37 AM   #12
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
Originally posted by djQUAN
can the TIP2955/3055 pairs be replaced by TIP35/36?
would be using it in an amp..... a quick look at their datasheets and I think it is possible?
yes, get the one with a C at the end like tip35c/36c.......
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 21st May 2007, 02:48 AM   #13
Workhorse is offline Workhorse
Workhorse's Avatar
I have onced used 2N3055HV rated at 100V BVCEO with rails +/-40VDC rails
Old 21st May 2007, 03:05 AM   #14
Samuel Jayaraj is offline Samuel Jayaraj  India
There is also the 2N3055HV version which can withstand slightly higher voltages than the type without the HV markings, but they are worse for audio.
Another 60V version is the 2N3055E which has a higher fT than other types and is best suited for audio. J.L.Hood used it in his 1996 Class A amp.
Similar transistors also come in another flavour MJE3055/2955 and ofcourse, as already mentioned TIP3055/2955.
Sam
Old 21st May 2007, 03:19 AM   #15
Workhorse's Avatar
ON Semi 2N3055HV has got same Ft 4Mhz and same other specs as normal 2N3055, there is no point for worst performance in audio....
High voltage capability doesnot lead to poor performance, but increase reliability.
Old 21st May 2007, 03:26 AM   #16
Kanwar, may be you should read D.Self's article called "Load Invariant amplifier".
Sam
Old 21st May 2007, 03:38 AM   #17
Workhorse's Avatar
I am not addicted to Self's amp Bible like you, sorry
Old 21st May 2007, 08:21 AM   #18
destroyer X is offline destroyer X  Brazil
destroyer X's Avatar
Default I am not addicted to Doctor Self bible also
But i am not sorry because of that....as i have readed and there are many things that i like there.
For sure, what he says is not a religion to me....i have constructed his amplifier.... and i made it twice (made it last month once more)...and the amplifier show me that he is very distant from "divine".... or, at least his "creation" are "not enougth" to my ears.
regards,
Carlos
How many maximum Vcc for TIP2955 & TIP3055?Hide this!Advertise here!
TIP2955/3055 matched pair - where to find? bobdole369 Solid State 14 30th July 2009 02:24 PM
HornResponse Maximum SPL bubblersound Subwoofers 3 21st June 2009 03:07 PM
Arcam Alpha 1 amplifier (30w) (TIP2955 / TIP3055 output stage) ash_dac Solid State 32 14th February 2009 04:43 AM
feedback on this tip2955/lm317 supply jarthel Power Supplies 2 2nd August 2007 12:38 AM
Maximum device dissipation smithy666 Solid State 15 1st August 2007 08:45 AM
Copyright ©1999-2017 diyAudio
